Havoc
Posted: Mon Sep 15, 2008 5:16 am Post subject: Idle-Surge |
I have been trying to pinpoint a nasty case of Idle surge when I'm at a stop. it comes and goes but its getting to a point that If I'm at a Stop the RPM's Jump then the car stalls. Runs just fine while driving and there are days I dont have the issue but as of late it seems to be worse.
Any Ideas ? Could it be the IAC sensor going bad? _________________ 1986 White vert McLaren# 196 |
Joined: 26 Aug 2004 Posts: 6205 Location: Northern New Jersey GSP Exit 148
trvlnmann
Posted: Mon Sep 15, 2008 12:40 pm Post subject: |
I would start by running the diagnostic codes. If you have never done it before it's easy to do. See what codes come up and go from there.
The IAC is a possibility, as is TPS, vacuum, EGR and so on. |
86capriasc
Posted: Mon Sep 15, 2008 1:47 pm Post subject: |
Check out this site, you will have no problems figuring out your problem. Joel is a wiz, and great info from everyone over there.
http://sbftech.com/index.php?board=20.0
Mike _________________ 1986 ASCMclaren #108
stock E7 short block, explorer intake, 65mm TB, home built Gt45 turbo kit, 3.08s, Borla cat-back, '05 slot maf, Gt-40p heads, TFS1 cam, 80lb injectors, E85, Qaurterhorse tuner. |
Havoc
Posted: Mon Sep 15, 2008 9:37 pm Post subject: |
wow I hope it isnt the EFI, I get to a stop and it idles rough and stalls at times. I'm hoping cleaning up the throttle body will help. Thanks for the site I will check it out. _________________ 1986 White vert McLaren# 196 |
mandra
Joined: 30 Aug 2004 Posts: 188 Location: South Huntington NY
Posted: Tue Sep 16, 2008 2:13 am Post subject: |
Also check hard for vacuum leaks. They are a common cause on these old dogs. |
xbgt
Posted: Tue Sep 16, 2008 2:22 am Post subject: |
I can tell you exactly what it is, the Idle Air Flow Control. It sorta looks like a minature fuel pump, it will be up near the throttle body. They go wacky at times. Just swap a new one on and she will be happy again. You can probably grab one at any Upull it place as well. And, I have found one off a 2.3 works just the same. I had an Aerostar van with a 3.0 in it, it wanted one per year and also an Explorer, about every 18 months, not sure why. Anyhow, it just an 8mm socket and one snap on plug, can change this is less than 5 mins.
Hope that helps,
Chris _________________ 1985 GPIV
1986 ASC Vert
1986 Eurocoupe #13
a few Capri's
Aussie Ford's
www.LastV8.com |
Joined: 22 Aug 2005 Posts: 17 Location: San Diego, CA
Posted: Tue Sep 16, 2008 10:32 pm Post subject: |
I had the same problem with my other mustang surging at every red light. It turned out to be a vacuum leak and man was it a pain to pin point. All of the suggestions mentioned above are dead on. Start by running your codes. |
Havoc
Posted: Mon Sep 22, 2008 3:19 am Post subject: |
UPDATE!!!! I took off the IAC and cleaned it with some MAF cleaner and got a new TPS sensor at Advanced for 39.99 and she is running better than ever. Thanks for the Help . _________________ 1986 White vert McLaren# 196 |
xbgt
Posted: Mon Sep 22, 2008 9:26 am Post subject: |
Havoc wrote: | UPDATE!!!! I took off the IAC and cleaned it with some MAF cleaner and got a new TPS sensor at Advanced for 39.99 and she is running better than ever. Thanks for the Help . |
Awesome!! _________________ 1985 GPIV
1986 ASC Vert
1986 Eurocoupe #13
a few Capri's
Aussie Ford's
www.LastV8.com |
