Havoc
Posted: Fri Mar 23, 2012 9:12 pm Post subject: Need new Tranny |
so my U-joints went out and made a mess of things with my tranny. I wanted to confirm with you guys is our (86 convert) is the AOD? To my surprise I'm having a hard time finding one on the Middle TN area. _________________ 1986 White vert McLaren# 196 |
capri50asc
Joined: 26 Dec 2009 Posts: 290 Location: Canton Michigan
Posted: Fri Mar 23, 2012 9:47 pm Post subject: Transmission Tip |
Your car has the AOD transmission. There is three aftermarket companys that sell aftermarket AOD transmissions:
B&M racing and Performance $1,750
Contact B&M directly
TCI Automotive has two versions both around $2,025
Contact TCI through Summint Racing or Jegs High Performance
Performance Automatic Racing $2,200
All these transmission are built better then the factory units from Ford Motor Company. With features like:
Stronger fricton Plates
Kevlar overdrive bands
Heat treated Vasco shaft
Cooler operating temps
Improved lubrication
Give them a call!
Chris
negusm Site Admin
Posted: Sat Mar 24, 2012 2:50 am Post subject: |
The transmission will be stamped with the car's vin. You may want it rebuilt. _________________ 1985 ascMcLaren Coupe - Midnight Blue
Under Restoration |
hanksgt
Posted: Sat Mar 24, 2012 6:49 am Post subject: Re: Need new Tranny |
The front seal went in my '89 AOD at 180,000 miles in September. I had the local transmission shop rebuild mine for $1,050. I wanted to keep my ASC all matching. 1,000 miles so far and running very well.
Havoc wrote: | so my U-joints went out and made a mess of things with my tranny. I wanted to confirm with you guys is our (86 convert) is the AOD? To my surprise I'm having a hard time finding one on the Middle TN area. |
_________________ Hank
Phoenix
'89 ASC #176
'87 ASC #134
'85 GT |
