85asc239
Posted: Mon May 21, 2012 1:29 am Post subject: screw pull down motor |
Does anyone know if the pull down motor on the mustang was shared with the chevys?
They were both converted at ASC at the same time.
Just wondering, because it might make sourceing them easier.
I know the pull down motor on the capri is a trunk motor from a lincoln |
KHummel66
Joined: 11 Jun 2006 Posts: 450 Location: Troy (Dayton) OH
Posted: Tue May 22, 2012 12:50 am Post subject: Re: screw pull down motor |
85asc239 wrote: |
Actually it's from a Cadillac. _________________ 1986 ASC vert - #86-0001
1986 ASC vert - 3.8SC v6
1985 ASC vert - Black/Tan/Tan
1985 ASC coupe - modified
1985 ASC coupe - roller
1983 Crimson Cat V6
1966 Cobra replica |
Posted: Tue May 22, 2012 2:23 pm Post subject: Motor |
It seems they are pretty common General Motors product. I think there is a 3 wire and a 4 wire unit or maybe the switch part on top has the 3 wires. It was easy to find on Ebay a while back including a reproduction plastcic housing. You should be able to score one for $50-$100. _________________ Kevin Gold card MCA Judge for Fox Body
shelbyscarab
Joined: 18 Jul 2006 Posts: 1009 Location: The Buckeye State
Posted: Tue May 22, 2012 3:38 pm Post subject: |
I need to pick one up. Mine is toast.
I've noticed the last 5 years alot of people running into this problem, many have reached their life span it seems.
I've heard so much conflicting advice on these, its hard to get a grasp on what is what.
I've heard chevy, I've heard cadillac, Lincoln...... specific years.
Hopefully I can find the right one on Ebay....
Anyone have any part numbers? _________________ 1988 ASC McLaren #688 |
RareFox
Posted: Tue May 22, 2012 5:34 pm Post subject: |
To add a few cents worth on the topic - Seems more common for the internal gears to cause problems than the actual motor itself to fail. Considering it's only used for about 3 or 4 seconds at a time it seems like the motor should last a long, long time. Of course there is potentially the matter of age and the possibility of water intrusion. That's a whole 'nother ball of wax.
On mine the top completely jammed. Motor absolutely would not release. Turned out the internal gears were the issue. Motor itself was fine. Words of wisdom: Heed Sandy's prior warning about NEVER using the motor to pull the top down completely tight against the tonneau cover! After much contemplation and several attempts, it is a repairable scenario as long as the nylon teeth aren't already heavily worn or stripped. Posted extensively on the topic some months ago. Not sure how to link to the old post but it's on here. Hope this helps! _________________ 1988 ASC-McLaren Red/Blk/Gray 5-speed
1990 Kawasaki Ninja ZX-10 Superbike (Update - SOLD!)
Various other rusty junk strewn about the yard
No blood in these veins... thats Mobil-1~!! |
Posted: Tue May 22, 2012 9:12 pm Post subject: Motor |
The Capri uses 84-86 GM part, caddy and others all the same. I am sure you can find the part numbers if you do a search on ths site. _________________ Kevin Gold card MCA Judge for Fox Body
davis388
Posted: Wed May 23, 2012 12:51 am Post subject: |
You can take out the nut on motor and use it manually. a pain but it works |
Joined: 26 Aug 2004 Posts: 6205 Location: Northern New Jersey GSP Exit 148
Posted: Wed May 23, 2012 1:03 am Post subject: |
bUT..... YOU DID not EXPLAIN why IT IS important TO NEVER TO PULL THE TOP ALL THE WAY AS IN " NICE AND TIGHT"
iF SHE JAMS WHEN THE TOP D O W N ...... YOU NEED TO GET IT UP LIKE.....NOW !!!!!!!!! OTHERWISE YOU CANNOT USE THE CAR OR PARK IT OUTDOORS.
SO.... IF YOU PLACE YOUR FINGERS UNDER THE BACK HEM OF THE CLOTH TOP, REACH AROUND WITH RIGHT HAND AND PUSH THE BUTTON, WHEN YOU FEEL THE TOP'S HEM TIGHTEN ONTO YOUR FINGERS THEN QUICKLY LET GO.
THIS GIVES YOU THE LEEWAY TO GO THE OPPISITE WAY THAT YOU WISH TO GO, AND WILL FREE THE MOTOR AND / OR GEARS UP - AT LEAST SO YOU CAN HAVE A CLOSED CAR. _________________ Sandy passed away in 2012. He will be forever missed.
http://public.fotki.com/ascmclaren/ascmclaren_capris/sandys_mclarens/ |
shelbyscarab
Posted: Tue Jun 05, 2012 5:50 pm Post subject: |
Ok fellow ASC owners......
I'm having the dealership, where I purchased my car, work on my top motor mechanism. They aren't having much luck. The top is up, which doesn't allow for hardly ANY room to work to get that motor out or removed. The solinoid does release the tonneau cover, but thats it.
Any advice??? and yes, we tried "jumping" the motor with a sudden electrical jolt, but it didn't work.
(If the top was down this would be 100x simplier..... obviously).
shelbyscarab
Posted: Thu Jun 07, 2012 5:12 pm Post subject: |
Really? no one?
Everyone on vacation?
Any advice would be appreciated. _________________ 1988 ASC McLaren #688 |
Posted: Thu Jun 07, 2012 5:26 pm Post subject: Motor |
I believe the 87 and up are different than the earlier ones. On my 85, I just use the latch and no motor (in place but not working). Just have to fit the fingers in the gap between the tonneau and the trunk lid to lift. I have yet to look at my 88 as I have only had it a few weeks and all is working.
On the 85, the top is latched by a lever on the tonneau. Lift up, releases the top hook, lower tonneau latches the top hook, so get it in place before lowering the last 6 inches or so. Works like a trunk lock to hold the tonneau down and the motor pulls the whole thing down.
Three steps open/close
-engage hook
-motor pull down or leave in down position and push to latch position
-latch tonneau lock (like trunk lock)
Open is the reverse. _________________ Kevin Gold card MCA Judge for Fox Body
Eric's 88 ford Mclaren
Posted: Sun Mar 23, 2014 12:22 am Post subject: New to site- 88mustang mclaren tonneau pull down motor |
New to this site. I have 88 mustang mclaren and my convertible top will not release from the tonneau top. I here the motor working, but it will not release it. I been reading through this site and tried just about every idea everyone posted. Is there a manual release latch somewhere on the car or any other special trick to get this releases? Please help |
