U-MAN
Joined: 11 Aug 2008 Posts: 198 Location: Upper Bucks, PA
Posted: Sun Dec 09, 2012 7:40 pm Post subject: Windshield Molding - Cracking |
Here is a question that I've had for awhile. The crackings that show up in the upper corners of the moldings, on the 'verts. Dose anyone think they are caused by, A. Cowl Flex, or B.Air getting up under it. Also, I would like to ask,Has anyone installed Sub Frame connectors, under their cars to stop Cowl Flex on the 'verts? Would really Like feed back from you guys. I know there is a wealth of knowledge out there. Thanks Steve |
hanksgt
Posted: Mon Dec 10, 2012 7:16 am Post subject: Re: Windshield Molding - Cracking |
Exterior molding on my '89 is holding up ok. I didn't do sub-frame connectors but years ago I added a Maximum Motorsports strut tower brace (it bolts to the strongest part of the firewall at the pinch weld, unlike others) and it stiffened the front of the car.
I was thinking about sub-frame connectors, but hate to modify the car that much.
U-MAN wrote: | Here is a question that I've had for awhile. The crackings that show up in the upper corners of the moldings, on the 'verts. Dose anyone think they are caused by, A. Cowl Flex, or B.Air getting up under it. Also, I would like to ask,Has anyone installed Sub Frame connectors, under their cars to stop Cowl Flex on the 'verts? Would really Like feed back from you guys. I know there is a wealth of knowledge out there. Thanks Steve |
_________________ Hank
'85 GT |
bryan
Posted: Thu Dec 13, 2012 6:29 pm Post subject: |
I suspect it's cowl flex, but once they crack air can be a big problem. Make sure it's secure along the top. One day I was on a road trip with mine and all of a sudden air got under it and the whole windshield started shaking violently. It was scary.
I put the Maximum Motorsports strut tower brace on as well, but my molding was cracked at the corners prior to installing it. _________________ '87 Guards Red ascMcLaren (#398) |
U-MAN
Posted: Fri Dec 14, 2012 3:57 am Post subject: |
Thanks for the feed back info on the cowl problem. I also have been lookin' at the Maxium Motorsports product line. Their stuff looks to be well made and up for the job. Not that my car should get anything less. I should have the life that car has! It dosen't get many miles on it, but it's still my big kid toy. I thank you guys once more for your replys, and input. |
Tom
Posted: Sat Dec 15, 2012 1:08 am Post subject: Windshield Molding - Cracking |
I had the same problem with mine. You can't put frame connectors on bc we already have them. A strut tower brace is no good on our cars either bc it very well could start tearing out at the cowl. It is def, "b" air gets under it and lifts it up and starts to flap around 60 mph and higher. It doesn't lift as much with the top up, but when it's down it's bad. I tried butyl tape and it held for awhile but I think I'm gonna go with regular 'vert moldings bc they are 3 piece and are not plastic. Sorry to offend any purists on here but I'd rather have the 3 piece than a cracked up one. IMO |
