Joined: 25 Aug 2004 Posts: 5063 Location: Charlotte, NC
Posted: Fri Jan 04, 2013 8:44 pm Post subject: |
Tx Trooperstang wrote: | Goodyear Gatorback Repops are available now if some of you don't know.
Tom[list=][/list] |
Problem is that these were never used on our cars.
At least for the Capris, they were lower profile tires and tough to find now.
Joined: 29 Aug 2004 Posts: 703 Location: San Mateo, California
Posted: Fri Jan 04, 2013 8:53 pm Post subject: Tires |
Double post _________________ Kevin Gold card MCA Judge for Fox Body
84 SVO 24,000 miles
03 Mach I 7,900 miles
89 LX Vert
14 CA Special
69 Mustang coupe
67 T-bird 47,000 miles
16 F250 |
Yes, they are available at $325 per tire. Wtf.
While I put nos parts on my car, it's more of a daily driver. I have 3 car now with dried out side walls which will never get worn out. I dont see it as a good long term investment as are nos parts. _________________ Kevin Gold card MCA Judge for Fox Body
84 SVO 24,000 miles
89 LX Vert
14 CA Special
69 Mustang coupe
16 F250 |
Tx Trooperstang
Posted: Fri Jan 04, 2013 11:14 pm Post subject: |
I have a contact from the SSP Web site that they can be obtained cheaper. Less than $280.00 a tire.
Tom _________________ Coming soon # 1079 |
AZCruisen
Joined: 01 Jan 2013 Posts: 27 Location: Surprise, Arizona
Posted: Sat Jan 05, 2013 1:24 am Post subject: |
Well the 20's are off and the stock wheels back on, albeit missing the center caps. I went with the Falkens, and at $77 a tire they will work fine. Tread looks good on it actually, and they are the proper size. Can't wait to take it for a spin to see how much better it rides now compared to those 20's. Does anyone know if there is a comparable center cap that is cheap that I can throw on for now until I can justify the $180 for the proper ones?
Hank, I will be taking it up there for sure now since I have the wheels on. We will be there probably around noon. Still have to clean it up tomorrow morning. |
Posted: Sat Jan 05, 2013 1:35 am Post subject: Caps |
If you have the old center caps, someone made stickers. Which falkens did you get, 512 or 912? _________________ Kevin Gold card MCA Judge for Fox Body
84 SVO 24,000 miles
89 LX Vert
14 CA Special
69 Mustang coupe
16 F250 |
AZCruisen
Posted: Sat Jan 05, 2013 1:46 am Post subject: |
Here are a couple photos from when I loaded her up to bring it home.
Posted: Sat Jan 05, 2013 3:06 am Post subject: Pics |
Looks better than i thought it would. My pull down motor has not worked long before it got it. I just used the latch to release it and stick my fingers under it to release it. I think my relays are the problem but have not got around to troubleshoot. _________________ Kevin Gold card MCA Judge for Fox Body
84 SVO 24,000 miles
89 LX Vert
14 CA Special
69 Mustang coupe
16 F250 |
AZCruisen
Posted: Sat Jan 05, 2013 3:59 am Post subject: |
Tires are the 512. My pull down motor is busted in pieces. I am currently looking for a replacement from a caddy. |
Posted: Sat Jan 05, 2013 4:16 am Post subject: Motor |
You can find replacement plastic housings on eBay. _________________ Kevin Gold card MCA Judge for Fox Body
84 SVO 24,000 miles
89 LX Vert
14 CA Special
69 Mustang coupe
16 F250 |
Tx Trooperstang
Posted: Sat Jan 05, 2013 4:46 am Post subject: |
There are a set of caps on Ebay.
AZCruisen
Posted: Sun Jan 06, 2013 5:43 am Post subject: |
Thanks for the tip on the caps. Hope to get those! Cleaned up the car today. Man did it need it. Took her up to the Pavillons cruise in Scottsdale and had a blast.
[/img] |
Tx Trooperstang
Posted: Sun Jan 06, 2013 6:04 am Post subject: |
I learned something new about the tire sizes used. Coupe used 225 50 15 and Convertibles used 215 65 15 in 85'.
hanksgt
Posted: Sun Jan 06, 2013 6:46 am Post subject: |
Car looks great. So glad you're out cruising with it already. Don't forget the pizza cruise Sat Jan 27!
AZCruisen wrote: | Thanks for the tip on the caps. Hope to get those! Cleaned up the car today. Man did it need it. Took her up to the Pavillons cruise in Scottsdale and had a blast.
[/img] |
_________________ Hank
'85 GT |
Posted: Sun Jan 06, 2013 5:17 pm Post subject: Tires |
Pretty sure the vert. Used 225/60-15 tires _________________ Kevin Gold card MCA Judge for Fox Body
84 SVO 24,000 miles
89 LX Vert
14 CA Special
69 Mustang coupe
16 F250 |
