Dr Cobra
Joined: 23 Feb 2013 Posts: 21 Location: Elizabethton, TN
Posted: Sun Apr 21, 2013 6:26 pm Post subject: convert electrical |
Has anybody put the tonneau cover solenoid on a different switch from the pull-down motor so that the solenoid isn't energized while the pull-down is running? This would give the motor more voltage to run. _________________ 1989 McLaren #150
1988 Mustang coupe-351W-88mm turbo |
Joined: 29 Aug 2004 Posts: 1823 Location: Commerce, MI
Dr Cobra
Posted: Tue Apr 23, 2013 10:06 pm Post subject: |
Thanks, I was thinking of using another switch hidden under seat maybe to control solenoid, but I will look into using a timer also. _________________ 1989 McLaren #150
mrheehee
Posted: Thu Apr 25, 2013 10:27 pm Post subject: |
I did eventually replace the pull-down motor, and the top. But I left the timer circuit in place and it still works great, no other switches necessary. |
Dr Cobra
Posted: Sat Apr 27, 2013 7:57 pm Post subject: |
mrheehee wrote: | I did eventually replace the pull-down motor, and the top. But I left the timer circuit in place and it still works great, no other switches necessary. |
Can you provide a little more detail on the timer you used ? _________________ 1989 McLaren #150
mrheehee
Posted: Thu May 02, 2013 12:43 am Post subject: |
It is an SSAC Time Delay Relay, 12V |
