scott86capri
Joined: 02 Oct 2013 Posts: 26 Location: Springfield, Missouri
Posted: Sun Oct 13, 2013 12:54 am Post subject: |
Look in my album and there are pictures in there. They are a coupe and the eurocoupe are the same car just less options on the eurocoupe. and no stripe kit supposed to have standard RS interior grey with red piping and supposed to not have smoked quarter windows 140 speedo was an option but as someone else said there is a lot of grey areas on the eurocoupe. also no B-303 cam though there is debate if any came with that something to do with emmisions or something and I think 2.73 gears which were standard on RS not the 3.08 the coupes enjoyed and no 50 series tires which made the final gear ratio more like 3.27 to 3.35 or something like that. To put it simply it is a plain jane coupe with ground effects and much more rare as mclaren only produced 21 of these the other 26 were made by or at Northtowne Lincoln Mercury in Kansas City. |
scott86capri
Posted: Sun Oct 13, 2013 8:44 pm Post subject: |
We'll after 3 hours with a 15 foot chain and my big 3/4 ton 4x4 popping it in opposite direction of the accident we got the frame and front end pretty close. It will still have to go on frame machine for sure but got shroud lined out and put belt on it last night filled with fluids and found the radiator was leaking. So this morning I put the original radiator from the red car into the asc filled back up with fluids and took her for her first spin. I must stay impressive power even with clutch slipping a little bit. Fixed a couple of marker lights replaced the third eye bulbs and took her up to get inspected passed with flying colors. So on Tuesday I will go to DMV and get tags. Yippy |
