ckj
Posted: Thu May 08, 2014 1:13 am Post subject: 87 spindles |
To put the maximum motorsports supsension on my 86 coupe I need to upgrade to 87 spindles. I'm told I can keep the 4 lugs but will my stock mclaren rims work with the 87 spindles and 11" brakes? Thanks -Ryan
*Edit, for some reason I thought the 87's switched to 5 lug, but just found out it's the 93 cobra, I guess all is well for 87 spindles?* |
Mustang Matt
Posted: Thu May 08, 2014 5:17 pm Post subject: |
Yes, they will bolt right up _________________ 85 Mclaren convt. - 70 Mach 1 - 79 Coupe - 84 SVO - 86 SVO convt - 93 FHP - 93 coupe DD - 94 Indy Pace car - 03 Mach 1 |
ckj
Posted: Sat May 10, 2014 12:27 am Post subject: |
Ok going to freshen up the brakes too as well, I guess for the 87 spindles easiest is to put on the svo calipers which I believe will work fine with my stock mclaren rims... Someone yell at me if they wont.
I'm sure some folks aren't happy that i'm modifying the car. I intend to keep every stock part and can always go back in the future. I want to drive and enjoy the car in the summer, maybe bring it to woodward next year etc. |
fascat
Joined: 11 Aug 2012 Posts: 112 Location: Greensburg, PA
Posted: Sat May 10, 2014 1:07 pm Post subject: |
ckj wrote: | I'm sure some folks aren't happy that i'm modifying the car. I intend to keep every stock part and can always go back in the future. I want to drive and enjoy the car in the summer, maybe bring it to woodward next year etc. |
I don't have a problem with it. After all, it is your car. If the upgrades are going to make it more enjoyable for you to drive, I say go for it. I'm glad to see you keeping it. Like you said, can always go back to stock if you want. |
MRBRUSER
Posted: Sat May 10, 2014 10:47 pm Post subject: |
You need 87 to 93 gt spindles rotors and calipers. Rims will fit right on. Also there's a company that makes rear disc brake set for fox body's. It keeps your stock fox body length axles. Changing the rear to disc brakes makes a big difference. I Have a Maximum motorsports k frame also.
Really good stuff. _________________ 1966 lincoln convertible
1971 Chevelle convertible ls3
1987 Grand national
1988 asc coyote swapped
1993 coupe 347 stroker
2016 Shelby GT350 |
ckj
Posted: Sun May 11, 2014 11:04 pm Post subject: |
I bought a nice set of refurbished spindles of ebay. I'm thinking I'll put the svo calipers on as they're a little better than the 87 calipers and I can get them and the svo master cylinder.
The 4 lug rear disc brakes are from SSBC, will be ordering them next week as well. As of now I'm going to keep the stock kmember and arms. |
MRBRUSER
Posted: Mon May 12, 2014 12:34 am Post subject: |
You'll need a adjustable proporting valve. A new e bake cables.
http://northracecars.com.
Try this site I bought most of my stuff for my cars. Also maximum motorsports has a lot of good stuff for the disc brake conversion _________________ 1966 lincoln convertible
1987 Grand national
2016 Shelby GT350 |
Mustang Matt
Posted: Mon May 12, 2014 5:39 pm Post subject: |
What he said !! Have the North brackets on my daughters GT, nice part and does the job correctly. _________________ 85 Mclaren convt. - 70 Mach 1 - 79 Coupe - 84 SVO - 86 SVO convt - 93 FHP - 93 coupe DD - 94 Indy Pace car - 03 Mach 1 |
