Help! High Beams don't work!
Mustang Munkey
PostPosted: Sat Apr 29, 2017 5:33 pm    Post subject: Help! High Beams don't work! Reply with quote
I have a 1989 ASC McLaren Mustang. I was driving the other night with my headlights on when I decided to switch to high beams. When I shifted the switch on the column to the high beam position I lost my headlights and my fog lights completely. When I shifted the switch back to low beams I got nothing but I wiggled the switch around and finally the low beams and fog lights came back on. Ever since I have low beams but no high beams. Has this happened to any of you and if so how did you fix it? Thank you, Mark
1989 ASC McLaren Triple BLUE #128
PostPosted: Sun Apr 30, 2017 4:11 am    Post subject: Switch Reply with quote
Sounds like to turn signal stalk switch went out. I'm not 100% sure. I never had this happen. Those switches have skyrocketed in price to $400. There are after market ones but often dont last.
FYI, the headlight switches are prone to failure too.
84 SVO 24,000 miles
03 Mach I 7,900 miles
89 LX Vert
14 CA Special
69 Mustang coupe
67 T-bird 47,000 miles
16 F250
PostPosted: Mon May 01, 2017 11:21 am    Post subject: Reply with quote
Would start with the headlight switch. Very common problem that when using high beams that the lights go off. Also a easy to find part and cheap. Under $50 last time I needed one.
4-barrel Mike
PostPosted: Tue May 02, 2017 11:44 pm    Post subject: Reply with quote
Repop: http://www.blueovalindustries.com/in4005.html
OEM: http://www.blueovalindustries.com/in3080.html
I would pull the multi-function switch and gently blow it out (20 psi or less) and reinstall. If that did nothing, I would get some electronic/switch cleaner/lubricant and liberally spritz the MF switch while working the switch to all positions. If that doesn't work, I would buy a new switch.
Mike
1985 5.0 SC, white/blue, modded by POs (more mods coming)
Mustang Munkey
PostPosted: Sun May 21, 2017 12:17 am    Post subject: Thank You, It Worked! Reply with quote
It was the multifunction switch and was worn out. I ordered a new one and it was simple to replace. It took me very little time to do and I love having high beams again! Thank you for your input.
