Greg
Posted: Mon Jul 13, 2020 10:23 pm Post subject: 1989 Top Bow won't release |
Hi, I'm getting my car ready to sell and now the top bow won't release. The tonneau releases and I hear the bow motor spin, but it seems to not be unscrewing. I can't figure out how to remove this motor as it seems like it is under the tonneau and not in the trunk as I read elsewhere here. Is there a repair manual anywhere or how do I go about fixing this issue. Did 1989 use the Cadillac trunk motor and if so which years Cadillac. Can I rebuild this motor or is it available anywhere besides ASC? Thanks |
birdiestobehad
Joined: 10 Nov 2011 Posts: 42 Location: Charlotte, NC
Posted: Wed Jul 15, 2020 2:44 pm Post subject: |
If you go to the ascmclaren.com web site, there is a section for "Service Manuals". Within that there is a section for "Convertible diagrams" and the first two pages are for operating the top. It does mention that the tonneau cover will not release if the trunk is ajar. There is also a section for the "Tonneau Cover".
I have an '86 and had to climb into the trunk to replace mine with a used one I found on ebay. I know the '87s on have a different motor, but never researched that. When I did mine, I searched this forum to find info for the motor.
Good luck! _________________ Terry M.
1986 'vert #118 |
Greg
Posted: Wed Jul 15, 2020 3:24 pm Post subject: |
Thanks for your reply. I can reach the tonneau release in the trunk which works. My problem is I can't get the rear bow up to get to the bow release motor under the tonneau. Not accessible from the trunk. Tonneau only goes up a few inches with the bow still attached. It is a type of cork screw as far as I know. Unless I am missing something on the ASC website, it doesn't address my issue. Maybe it is only for pre 1987. |
Greg
Posted: Thu Aug 06, 2020 9:05 pm Post subject: |
Greg wrote: | Thanks for your reply. I can reach the tonneau release in the trunk which works. My problem is I can't get the rear bow up to get to the bow release motor under the tonneau. Not accessible from the trunk. Tonneau only goes up a few inches with the bow still attached. It is a type of cork screw as far as I know. Unless I am missing something on the ASC website, it doesn't address my issue. Maybe it is only for pre 1987. | If no one knows the answer, anyone know whom I could find out from? The ASC site doesn't have the info I need.It assumes the 5th bow will release from tonneau to access the motor.I think the manuals are for the older cars with the Cadilac trunk release style. Doesn't specify. |
