Mustang Munkey
Posted: Sat Apr 29, 2017 5:33 pm Post subject: Help! High Beams don't work! |
I have a 1989 ASC McLaren Mustang. I was driving the other night with my headlights on when I decided to switch to high beams. When I shifted the switch on the column to the high beam position I lost my headlights and my fog lights completely. When I shifted the switch back to low beams I got nothing but I wiggled the switch around and finally the low beams and fog lights came back on. Ever since I have low beams but no high beams. Has this happened to any of you and if so how did you fix it? Thank you, Mark _________________ 1989 ASC McLaren Triple BLUE #128 |
Joined: 29 Aug 2004 Posts: 753 Location: San Mateo, California
Posted: Sun Apr 30, 2017 4:11 am Post subject: Switch |
Sounds like to turn signal stalk switch went out. I'm not 100% sure. I never had this happen. Those switches have skyrocketed in price to $400. There are after market ones but often dont last.
FYI, the headlight switches are prone to failure too. _________________ Kevin Gold card MCA Judge for Fox Body
Joined: 27 Jul 2005 Posts: 1126 Location: Ann Arbor Michigan
Posted: Mon May 01, 2017 11:21 am Post subject: |
Would start with the headlight switch. Very common problem that when using high beams that the lights go off. Also a easy to find part and cheap. Under $50 last time I needed one. |
4-barrel Mike
Joined: 30 Jan 2016 Posts: 159 Location: Portland, OR
Posted: Tue May 02, 2017 11:44 pm Post subject: |
Repop: http://www.blueovalindustries.com/in4005.html
OEM: http://www.blueovalindustries.com/in3080.html
I would pull the multi-function switch and gently blow it out (20 psi or less) and reinstall. If that did nothing, I would get some electronic/switch cleaner/lubricant and liberally spritz the MF switch while working the switch to all positions. If that doesn't work, I would buy a new switch.
Mike _________________ 1985 5.0 SC, white/blue, modded by POs (more mods coming) |
Mustang Munkey
Posted: Sun May 21, 2017 12:17 am Post subject: Thank You, It Worked! |
It was the multifunction switch and was worn out. I ordered a new one and it was simple to replace. It took me very little time to do and I love having high beams again! Thank you for your input. _________________ 1989 ASC McLaren Triple BLUE #128 |
