Posted: Thu Jun 05, 2008 4:30 pm Post subject: |
86capriasc wrote: | How would I measure it if I can get one? |
Good question. _________________ 1985 ascMcLaren Coupe - Midnight Blue
Joined: 29 Aug 2004 Posts: 1823 Location: Commerce, MI
Posted: Thu Jun 05, 2008 10:55 pm Post subject: |
i could exsplane but i have a very very hard time putting what i am trying to say into words. after you strugle reading through what i am trying to say you will still be clueless. maybe i can find a link online... _________________ ~Peter
1985 ASC McLaren Coupe |
Posted: Thu Jun 05, 2008 11:01 pm Post subject: |
ahhhh sweet copy and paste... i love google.
"Mike the cam lobe from top of point to heel (up and down), then mike it 90 degrees from that (sideways). Subtract the small dimension from the large"
the numbers might be off a bit but should be close to the .277" or .300"
B-C=A easy!
hope this helps!!! looks like the hard part will be learing how to read a mike _________________ ~Peter
86capriasc
Posted: Fri Jun 06, 2008 12:01 am Post subject: |
I will try it with my dial caliper.
Okay, I get .310 difference. _________________ 1986 ASCMclaren #108
stock E7 short block, explorer intake, 65mm TB, home built Gt45 turbo kit, 3.08s, Borla cat-back, '05 slot maf, Gt-40p heads, TFS1 cam, 80lb injectors, E85, Qaurterhorse tuner. |
86capriasc
Posted: Fri Jun 06, 2008 12:11 am Post subject: |
Looks like I may be doing a cam swap soon. I just don't know if the valves will clear the pistons on the stock 89 block with 1.7 RR. _________________ 1986 ASCMclaren #108
Posted: Fri Jun 06, 2008 12:26 am Post subject: |
.310" humm... i would think that you would have gotten a reading alot closer to .300" like .302" or .299" what did you use a mike or a caliper? _________________ ~Peter
86capriasc
Posted: Fri Jun 06, 2008 12:29 am Post subject: |
I used a caliper. _________________ 1986 ASCMclaren #108
Posted: Fri Jun 06, 2008 12:30 am Post subject: |
an E303 cam has a lift of .311"
i dont know what you got... its for sure not a stock cam
Posted: Fri Jun 06, 2008 12:32 am Post subject: |
86capriasc wrote: | I used a caliper. |
was it a dile caliper? _________________ ~Peter
86capriasc
Posted: Fri Jun 06, 2008 12:34 am Post subject: |
The caliper I have is old so it may not right on either. I will try took take it down to my buddies house later tomorrow or over the weekend. He is a machinist so he has better tools than I. I will have him mic it. He can check both intake and exhaust for me. I'm not sure which one I checked. _________________ 1986 ASCMclaren #108
Posted: Fri Jun 06, 2008 12:37 am Post subject: |
I and E should be the same if its a B or E cam... sounds like you have a B cam and a crapy caliper. i would for sure have your buddy mic it out for you if you plan on installing it. he might even degree it for you! _________________ ~Peter
86capriasc
Posted: Fri Jun 06, 2008 12:40 am Post subject: |
Just checked the adv.
Ford Racing hydraulic roller camshaft M-6250-B303 that provides significant horsepower increases above 4000 RPM and good low-end torque. Valve lift is .480" on both intake and exhaust. Duration at .050" is 224 degrees on both intake and exhaust
Sorry i did my math wrong
1.42
-1.71 as written on my paper
.31 I had figured.
actual .290 _________________ 1986 ASCMclaren #108
Posted: Fri Jun 06, 2008 12:55 am Post subject: |
yeah ford figuerd in the rocker ratio to get the valve lift of .480"
.300 x 1.6 (rocker arm) = .480" of lift at the valve.
you will have to use a degree wheel to find the duration if you dont know for sure what the cam is. _________________ ~Peter
