MercRS
Posted: Fri Jan 28, 2005 8:39 am Post subject: Coupe center caps.............. |
which ones are better? my 85 has none and my Euro Coupe I am not sure. _________________ 81 Mercury Capri RS
70 Mercury Montego
71 Mercury Cyclone GT
69 Mercury Marauder X-100
70 Mercury Cyclone GT
86 McLaren Euro Coupe
85 McLaren Capri Coupe
03 Mercury Marauder
70 Ford Fairlane 500 SCJ DragPac
70 Mercury Cougar
73 Montego GT |
Posted: Fri Jan 28, 2005 1:39 pm Post subject: |
Which one is better? I guess I don't understand this either.
There are center caps for mounting from the inside or outside of your wheel depending on what wheel type you have.
Verts and Coupes got different styles of center caps.
MercRS
Posted: Sat Jan 29, 2005 4:17 am Post subject: |
is inside or outside design better?85 is a Coupe and the 86 is a Euro.
what would be better on mine. _________________ 81 Mercury Capri RS
70 Mercury Montego
03 Mercury Marauder
70 Mercury Cougar
73 Montego GT |
Posted: Sat Jan 29, 2005 4:26 am Post subject: |
MercRS wrote: | is inside or outside design better?85 is a Coupe and the 86 is a Euro.
what would be better on mine. |
What a weird response.
You need to match the correct cap for your wheels. If you have OUTSIDE mounting style wheels and buy INSIDE mounting style caps....you just wasted your money. For example, there are TWO different style Orange mesh wheels. TYP-34F is for OUTSIDE mounting caps ONLY. That is the early style wheel. Later in 86 they modified the wheel design for INSIDE mounting caps.
The only way I would classify one as "better" than another is that the "inside" mounting caps, won't fall off your car....and are harder to steal.
MercRS
Posted: Sat Jan 29, 2005 4:52 am Post subject: |
I stated in the first post that I had NONE on the 85.I thought they could use both. _________________ 81 Mercury Capri RS
70 Mercury Montego
03 Mercury Marauder
70 Mercury Cougar
73 Montego GT |
Posted: Sat Jan 29, 2005 4:58 am Post subject: |
MercRS wrote: | I stated in the first post that I had NONE on the 85.I thought they could use both. |
Ok. Now it makes some sense as to why you were asking what you were asking.
No, they can't use both styles. Take the codes off your wheels (check to make sure all 4 are the same) and if you're buying caps from Hank, he will send you the right ones based on the codes you give him.
I would actually be interested in seeing what kind of codes come off from your wheels as it seems most all 85 Coupes got the outside mounting caps (TYP-34F). It would be interesting to know when the changeover happened.
