Pull Down Motor 1984-86 $47.00 dollars
PostPosted: Mon Jul 20, 2015 7:12 pm    Post subject: Pull Down Motor 1984-86 $47.00 dollars Reply with quote
Hi Guys
My Pull down motor on my 1986 cracked at the housing and destroyed itself. But Amazon .com has them in the Automotive section. Go to: Automotive. Type in Pull Down Motor. Its Dorman part number 747-000 Took 5 minutes to put in, All you have to do is transfer the steel bracket and the hook unit to the new part. All for just $47.00
Thanks Chris Smile
PostPosted: Tue Jul 21, 2015 4:59 am    Post subject: Motor Reply with quote
Thanks. The last time is searched I found the plastic housing available as well pretty cheap.
shelbyscarab
PostPosted: Wed Jul 29, 2015 12:29 pm    Post subject: Reply with quote
Well if there is anyone else here that needs a pull down motor assembly for their '84-'86 Capri I have one.......... Mad
I bought the same one the OP bought on Amazon for $47(after someone told me this is the one I need - thank you very much for that) and found out just this week that it in fact is not the right one for a '87-'90 ASC stang.
I did find out a little more about my situation by the hot rod custom shop who worked on my car, the motor assembly is essentially two parts: the motor itself and the screw pull down mechanism. my motor is great, runs strong - however the screw pull down mech. is shot. Stripped. I technically just need the worm gear part, but don't know if I can get that by itself.
So, if anyone is interested I can ship it to you for $47. I'll pay for the shipping. Sad
