A pillar plastics? Are they the same?
7ftbill
PostPosted: Fri May 04, 2018 12:37 am    Post subject: A pillar plastics? Are they the same? Reply with quote
My "A pillar" interior trim/plastic pieces are brittle as hell, they are cracked in a few spots and I know I will have to pull these off eventually (need to do a heater core and maybe change the dash pad).
Are these specific to these cars and only an ASC part? or can I find a comparable year vert and pick some up?
(86 capri vert)
PostPosted: Fri May 04, 2018 2:23 pm    Post subject: Reply with quote
I'm pretty sure the A-Pillar covers are the same but maybe cut down at the top?
Changing out the Heater core is a major PITA, but it can be done. I would recommend watching some videos on YouTube about it. Also, it would be a good time to replace your AC evaporator while you're in there. I wish I would have replaced mine...
The good thing about the heater core drill is that you have to take everything out, so you get a chance to clean everything and put it back in.
You might as well replace your carpet if it is old.
PostPosted: Fri May 04, 2018 3:48 pm    Post subject: Reply with quote
Pulling the seats help, gives you more wiggle room. I should have stock Ford A-pillars would need to be painted
PostPosted: Fri May 04, 2018 7:54 pm    Post subject: Parts Reply with quote
Keep in mind most of the Ford parts are from the hatchback model not the convertible. The a pillars appear to be cut off and attached with paper based double sided tape at the top. Likely 79-86 to match the dash design.
84 SVO 24,000 miles
03 Mach I 7,900 miles
89 LX Vert
14 CA Special
69 Mustang coupe
67 T-bird 47,000 miles
16 F250
7ftbill
PostPosted: Thu May 10, 2018 7:17 pm    Post subject: Re: Parts Reply with quote
Thanks! I didn't think about them being from a hatch. Figured they could have started with a T-Top car but it does look like the doors were modified too
