7ftbill
Posted: Fri May 04, 2018 12:37 am Post subject: A pillar plastics? Are they the same? |
My "A pillar" interior trim/plastic pieces are brittle as hell, they are cracked in a few spots and I know I will have to pull these off eventually (need to do a heater core and maybe change the dash pad).
Are these specific to these cars and only an ASC part? or can I find a comparable year vert and pick some up?
(86 capri vert) |
Posted: Fri May 04, 2018 2:23 pm Post subject: |
I'm pretty sure the A-Pillar covers are the same but maybe cut down at the top?
Changing out the Heater core is a major PITA, but it can be done. I would recommend watching some videos on YouTube about it. Also, it would be a good time to replace your AC evaporator while you're in there. I wish I would have replaced mine...
The good thing about the heater core drill is that you have to take everything out, so you get a chance to clean everything and put it back in.
You might as well replace your carpet if it is old. _________________ Dan
67 Mustang GTA Convt |
Joined: 27 Jul 2005 Posts: 1126 Location: Ann Arbor Michigan
Posted: Fri May 04, 2018 3:48 pm Post subject: |
Pulling the seats help, gives you more wiggle room. I should have stock Ford A-pillars would need to be painted |
Joined: 29 Aug 2004 Posts: 756 Location: San Mateo, California
Posted: Fri May 04, 2018 7:54 pm Post subject: Parts |
Keep in mind most of the Ford parts are from the hatchback model not the convertible. The a pillars appear to be cut off and attached with paper based double sided tape at the top. Likely 79-86 to match the dash design. _________________ Kevin Gold card MCA Judge for Fox Body
7ftbill
Posted: Thu May 10, 2018 7:17 pm Post subject: Re: Parts |
svo413 wrote: | Keep in mind most of the Ford parts are from the hatchback model not the convertible. The a pillars appear to be cut off and attached with paper based double sided tape at the top. Likely 79-86 to match the dash design. |
Thanks! I didn't think about them being from a hatch. Figured they could have started with a T-Top car but it does look like the doors were modified too |
