Rear Door Sill Trim?
PostPosted: Mon Nov 12, 2018 2:52 pm    Post subject: Rear Door Sill Trim? Reply with quote
IN my roadster, there is no trim past the stock door sill trim, so I have about a 4 inch unfinished spot where the carpet comes up and over the frame. It looks pretty bad, so I would like to cover it--it looks like ASC just didn't finish that area?
Did they have any kind of trim back there?
I took my old kick panel and cut it down so that it tucked under the door sill cover and then dead ended at the storage cover. It is only about 5 inches long and about 5 inches tall.It looks like it is supposed to be there, but I cut it off before it went up the fender along the weatherstripping like it does in the front. The kick panel has a little turn at the top that doesn't match the turn of the weatherstripping at the back of the door, so it just wouldn't look right.
Has anyone done something similar?
PostPosted: Wed Nov 14, 2018 8:05 pm    Post subject: Door filler Reply with quote
You need this.
https://www.ebay.com/itm/84-87-ASC-McLaren-Capri-Mustang-outer-door-belt-trim-to-tonneau-RH-/202483015742
14 CA Special, 69 Mustang coupe
PostPosted: Thu Nov 15, 2018 12:35 am    Post subject: Reply with quote
I think I was a little unclear--pictures are always better.
This is how the door sill is not finished in my car. I did replace the carpet with the rubber backed style and the carpet didn't reach up and over the rocker panel so there is a gap which makes it look worse. My issue is that the door sill plate just stops and there is nothing for a few inches back to the felt. Just doesn't look finished. ASC had the quarter trim, why couldn't they cut it down to trim out the door??
This is the piece of the old front kick panel that I cut down to cover the gap. Now, I didn't cut it very well since this was a trial run, so it is jagged at the back where it hits the felt. If I were to try this again, I would spend a lot more time on it.
I had to cut the vertical part off that goes up the weatherstrip because it had a curve before it met the top weatherstrip piece. I might be able to straighten it out with a heat gun, but I wasn't thinking about that at the time. Also, I think I could tuck it behind the felt so that it looks like it is supposed to be there..
