Posted: Mon Jun 24, 2019 1:17 pm Post subject: Alpine 7272 Install Questions |
My 86 roadster came with an aftermarket removable face radio that works and sounds great, but I couldn't resist picking up an Alpine on eBay.
Alpine 7272 on eBay
I read in another thread that the Alpine wasn't installed with a box, so I'm feeling pretty good about the install. The wires are all labelled very well, so I have that going for me, too.
I did get an amplifier with the deck, and I recall hearing that the McLarens might have had an amp?? If so, where was it mounted?
I have the stock Kenwood rear speakers and I am adding the deluxe door panels, so I'm going to add door speakers. My current radio uses the dash speakers, but I'm thinking that I should go to the door and rear speakers only.
Is this how they are supposed to be set up?? _________________ Dan
67 Mustang GTA Convt |
Joined: 26 Dec 2009 Posts: 290 Location: Canton Michigan
Posted: Tue Jun 25, 2019 12:45 am Post subject: Radio for the 86 ASC |
From what I was told some of the early 86 ASC Coupes had the Alpine radios The remaining ones had the factory Premium radio with separate Amp
The convertibles in 1986 all had the Factory Premium radio system and no Alpines. The Amp is located right in the center of the top dash pad. If no one has removed it. Remove the top of your dash to get access . NOTE. Be careful you do not wire the amp in wrong as it can blow the radio. The Coupes have 4 Speakers the convertibles have 10.
The 85 -86 Stock radios is one of the worst radios to remove in some case you will need to remove the console and the floor heater chute.
Go luck Chris |
Posted: Tue Jun 25, 2019 12:49 am Post subject: Recaro Seats |
Also NOTE With the Roadster and Recaros you have the headrests that both have two speakers. 10 Speakers Non-Recarcos 6 speakers
