asc4life
Posted: Mon Jul 14, 2008 3:25 pm Post subject: gears???????? |
I have stock gears in my 1986 ascmclaren covertable i would like to change them but i am not sure what it allready has or what i shuld go to.
just want to make it feel more powerfull without messing things up... it has a tag on the cover it says 206f
l27a88
602 |
shelbyscarab
Joined: 18 Jul 2006 Posts: 1009 Location: The Buckeye State
Posted: Mon Jul 14, 2008 3:30 pm Post subject: |
I'm not sure if the capris were the same, but I think all the '87'-'90s came with 3.08s. Anyone? (3.55s would be nice) _________________ 1988 ASC McLaren #688 |
n20capri
Posted: Mon Jul 14, 2008 4:57 pm Post subject: |
my Coupe had 3.08's! I have a set of 3.55's for sale if your interested... _________________ Mike
86 9L SVO
www.mikemartinelli.com
www.baldguydesigns.net
negusm Site Admin
Posted: Mon Jul 14, 2008 5:41 pm Post subject: Re: gears???????? |
asc4life wrote: | I have stock gears in my 1986 ascmclaren covertable i would like to change them but i am not sure what it allready has or what i shuld go to.
l27a88
602 |
I *think* the l27 should be 3l27 which would be 3.27:1 Locking. The first number often is hidden by the bolt.
What does your door tag code for the axle say?
Under Restoration |
1985 Motorsport Capri
Joined: 28 Sep 2004 Posts: 517 Location: Dearborn, MI / Richmond, VA USA
Posted: Mon Jul 14, 2008 10:19 pm Post subject: |
3.27:1 were stock for automatics in 85/86. _________________ Jason Ringuette
1985 Mercury Motorsport Capri Registry
www.Motorsportcapri.com |
86capri62
Joined: 24 Jan 2008 Posts: 439 Location: Papineauville, Quebec, Canada
Posted: Wed Jul 16, 2008 2:46 am Post subject: |
I personnaly have had a 90 coupe 5.0L that I switched to 3.55 with a shift kit in the trans. It made quite a difference. But after a little while I would have prefer a 3.73. The engine was still very quiet and slow running at 55 with the 3.55. it could have handle the 3.73 easy I think, with even more fun and not much more gas. _________________ 87 Ferrari Mondial 3.2 cabriolet(sold)
86 ASCMcLaren vert (sold)
80 corvette (sold)
77 Ferrari 308 GTB(sold)
2005 MB SLK 350
2008 Rotorway helicopter |
asc4life
Posted: Wed Jul 16, 2008 6:16 am Post subject: |
373s is what i think i am going to get. It sounds like it the best all around gear for my aod. I was thinking 410s but that may bee pushing it if i decide to travle a long distances. not real concerned about gass as long as it is not real bad. i heard that one company sells 390s what may be what i realy want..I have to think it threw alot before i make a choice sence it will cost me about 500.00 for parts and labor. I want to get it right the first time for that price. |
cobrajeff
Joined: 04 Sep 2004 Posts: 24 Location: White Lake, MI
Posted: Thu Jul 17, 2008 1:55 pm Post subject: 3.73 Gears |
I replaced the 3.27's in my '85 AOD convert with 3.73's, and I was very happy with the results. Also installed an "A" servo and valve body out of an '89 Lincoln LSC into the AOD.
Jeff |
ASCMCLRN
Posted: Wed Jul 23, 2008 2:35 pm Post subject: |
3.73's should be fine. 1986 Capri verts came with the 8.8 rear right? If not you might want to change it all together.
Nick |
Joined: 26 Aug 2004 Posts: 6205 Location: Northern New Jersey GSP Exit 148
Posted: Wed Jul 23, 2008 4:21 pm Post subject: |
1986 COUPES - Full Packaged (not EuroCoupes) WITH 4-SPEED AUTOMATIC TRANNY CAME WITH 3.73:1 RATIO,
if built under D32 (ascMcLaren) order code, followed by the code
indicating that it was to be a COUPE and not a Vert. _________________ Sandy passed away in 2012. He will be forever missed.
http://public.fotki.com/ascmclaren/ascmclaren_capris/sandys_mclarens/ |
ChuckG
Joined: 07 Apr 2009 Posts: 509 Location: Ann Arbor,MI
Posted: Tue Apr 07, 2009 7:09 am Post subject: Tire diameter effect? |
I was told way back when that my coupe's effective gear ratio was like 3:31 because the 225/50s were an inch shorter than the 225/60s the RS carried.
I wonder if they calibrated the speedo for that?
I do know even up, I'd smoke a 5.0 Mustang by a good deal. |
85McLaren
Posted: Tue Apr 07, 2009 11:47 am Post subject: |
I doubt they did. Too much work for that. That use to be a old trick people use to do. All you had to do was put a smaller tire and that would effectively increase your gear ratio.
Jason |
negusm Site Admin
Posted: Tue Apr 07, 2009 1:12 pm Post subject: |
Yes, they did redo the speedo gear.
The difference in the stock tire height and the ones asc used was like 5-7mph at about 65mph.
My speedo was always off when I was driving my car back in college and got a ticket because of it too. At that time I had the "normal" height tires.
Under Restoration |
85McLaren
Posted: Tue Apr 07, 2009 2:17 pm Post subject: |
That would be the only thing they probably did (the speedo gear). That would be the cheapest and quickest this to do. I assume they just added the 3.27 gear in. Close enough for government work.
Jason |
tfs2121
Joined: 29 Aug 2004 Posts: 1823 Location: Commerce, MI
Posted: Wed Apr 08, 2009 11:47 am Post subject: |
hummm my speedo was always off even with the right tires. it was about 3-4 mph fast at 45 _________________ ~Peter
1985 ASC McLaren Coupe |
