07SGT5687
Posted: Mon Jul 11, 2016 1:12 am Post subject: Armrest removal? |
Anyone know the proper way to remove the door arm rests on an 88? Mines gotten a bit loose and I want to make sure all the support are on correctly. The plastic is getting a bit brittle and I don't want to break anything getting aggressive. I got the front area off, but the rear portion is not budging. I suspect I need to pop the light/reflector out? But again, 30 year old brittle plastic, I didn't want to experiment.
Thanks! |
wrightsvo
Posted: Tue Jul 12, 2016 6:16 pm Post subject: |
inside the light fixture, you should find a screw |
07SGT5687
Posted: Wed Jul 13, 2016 2:43 am Post subject: |
wrightsvo wrote: | inside the light fixture, you should find a screw |
Thanks, how doe I get "inside" the light fixture? |
birdiestobehad
Joined: 10 Nov 2011 Posts: 42 Location: Charlotte, NC
Posted: Wed Jul 13, 2016 11:30 am Post subject: |
Go to ascmclaren.com to the Service Manuals section. There is a 2 page section for "Door". this has a one page written description and a one page diagram. The first few steps describe removing the arm rest. I believe this is just for the Mustangs as it did not match my Capri. I ended up getting a used Chilton book on amazon. _________________ Terry M.
1986 'vert #118 |
wrightsvo
Posted: Fri Jul 15, 2016 2:01 pm Post subject: |
The clear lens has a clip on both ends. You can carefully pry it out for access. |
