For Sale: 1987 Supercharged 448hp 6-spd ASC McLaren Convert.
Post new topic   Reply to topic    ascMcLaren Enthusiasts Forum Index -> Classifieds
GoRovers
PostPosted: Tue Mar 10, 2020 4:47 am    Post subject: For Sale: 1987 Supercharged 448hp 6-spd ASC McLaren Convert. Reply with quote
For Sale: 1987 Supercharged 448hp 6-speed ASC McLaren Convertible
Hemmings ad here: https://www.hemmings.com/classifieds/cars-for-sale/ford/mustang/2385840.html
YouTube video here: https://youtu.be/6cw3RrBTb8U
This rare Jet Black 1987 ASC McLaren convertible Mustang has 100,500 miles. (Seller has all receipts and documentation, going all the way back to the original window sticker.)
The previous owner, at 83k miles, converted the car into the machine it is today, including new 342 cu. in. (5.6 liter) motor, supercharger, and matching high-performance 6-speed transmission, Wilwood brakes, handling package and exhaust. This rocket ship has been Dyno-tested at 448 horsepower, and 455 foot-pounds of torque. Here is the long list of performance upgrades:
- New motor: Ford Sportsman Block, 342 cubic inches (5.6 liter)
- Crankshaft: Eagle
- Pistons: SRP
- Camshaft: X303
- Cylinder Heads: AFR 185 O-ringed lock wire
- Power Adder
- Vortech S Trim
- Snow Methanol Injection
- Intake Manifold: Holley System Max
- Throttle Body: Holley 75 MM
- Fuel System: 481b Injectors
- Exhaust: JBA Ceramic Coated Headers + Flow master Hi Flow Cat's + Magnum mufflers
- Transmission: FRPP T56, 6-speed, King Cobra Clutch, FRPP Aluminum Drive Shaft, Pro 5.0 Shifter
- SCT Dyno Tuned with Chip
- MSD Ignition with control knob (currently bypassed)
- Ford Motor Sports Strut Tower Brace
- MM Subframe Connections, Full Length welded plus interior B frame connectors
- Stock K Member, Aluminum Steering Rack Bushings, MM - Torque Arm, MM - Panhard Bar, MM - Coil over front, MM – Hypercoil over 250 lbs Springs, Bilstein HD Struts, Bilstein HD Rear Shock with MM Adjustable rear, Lower control arms Heavy Duty, Hoskins- Caster camber plates, Flaming river quick ratio power rack and pinion, solid steering shaft road race
- Wilwood 6-piston Brakes, Drilled and slotted front with stainless steel brake lines, Rear Four piston brakes drilled and slotted with drum parking brake
Take a breath... there's more:
- Wilwood Prop Valve
- Upgraded brake master cylinder and booster
- Fluidyne high performance aluminum radiator
- Aluminum overflow tube
- Spall slim fan electric radiator fan duel
- Richard Racing aluminum ultra grip pulley for supercharger 2,950
- PCV oil separator
- High Torque mini starter
- Mishimoto Mustang Performance oil cooler (stainless lines)
- Cockpit fuel pressure gauge and boost gauge
- Front blinder laser jammers with cockpit switch
- Polyurethane swaybar end links
- Auburn Rear End 373 gear with 31 spline axles
- High Flow 255 Iph fuel pump 37. Kill switch to motor
And to top everything off, current owner recently added:
- Recaro sport seats, leather back, heater option
- 4-point seatbelt harness; Scroth ASM Auto Control II Blue
- New carpet and rebuilt center console
- New Sony stereo and new speakers in doors
This car has its original Jet Black paint. It looks amazing! No body damage or dings. The soft top is in great shape.
This California car was JUST SMOGGED! Clean CarFax. Pink slip in hand. Ready to go!
$19,988.
Owner Frank can be reached at (562) 708-292 Eight‬. Car is located in Long Beach, California.
Post new topic   Reply to topic    ascMcLaren Enthusiasts Forum Index -> Classifieds All times are GMT
