Battery For 1985 5.0SC
Agent-J
Post by Agent-J »
I am looking for a MotorCraft Battery for my 1985 5.0SC the dealer says they are longer avalibable I do not care is it date coded correctly I just want a MotorCraft battery. The car has 17,000 orginal miles and would like to keep it as original looking as possible.
Does the battery have to be GOOD. For I see lots of batterys but they are bad and thats why i see them. So what I'm saying is that I may come across a battery that whould LOOK OEM but not start the car.
You bought the Red Capri 5.0SC that was on e-bay 2x in Ohio ?? Yes!! (?)
Battery
The dealer was too lazy to look it up. There is a Motorcraft battery available. I just bought one a few Months ago for my 84 SVO. I don't recall the model but I will try to go look at it.
The Motorcraft website lists 2:
BXL56A 84 Month Wet Battery
500 CCA - RESERVE MIN = 90
TESTED TOUGH PLUS
18 MONTH FREE REPL
BXT56 100 Month Wet Battery
550 CCA - RESERVE MIN = 86
TESTED TOUGH MAX
36 MONTH FREE REPL
Now I am looking for an original battery which will probably be nonfunctional. I need this for the class I show my SVO in. I haven't located the exact model yet but it is a white case and black to battery.
Agent-J
Post by Agent-J »
No I bought the car from Wyoming last year it is white in color.
SVO413
The dealer actually looked it up and ordered it then called me back to tell me it was no longer available.
Battery
I just checked with the local Motorcraft distributor and both are not obsolete and are still available and in stock. Like I said they are too lazy to order it. I had the same problem but when I gave them the part number it showed up in a few hours!
The previous listing in the Ford books is probably no longer available. Go to the Motorcraft web site.
You didn't list your city so I could check the local supplier.
Kevin
I need a battery. What's the Cold Cranking AMps on them? What's the part number for a correct one if anyone knows?
Thanks.
Battery
:roll:
Sometimes I'm a bit slow with the humor or was my previous post in invisible type.
You need what is called a Group 56 battery should have around 530 CCA.
