An ascMcLaren forum for 84-86 Capri and 87-90 Mustang based cars modified by Automotive Speciality Corporation, a Division of American Sunroof Corporation. (no affiliation)
I was confused. I thought maybe it was pics from 2 different wheels.
Regardless, you have at least one inside/rear loading wheel. You better check the others. I was under the impression that 87+ cars got the inside loading caps.
Although if the previous owner is like my friend, he may have gone through 3 wheels in 2 years and have gotten replacements.
I will check my wheels, but no I didn't push it in. Those are 2 different wheels.
One with a cap and one without but appears someone put it on the inside (drum side) of wheel not out..LOL
In your first pic, you can see "TYP1734F" in raised print around the upper left of the wheel center. What I can't tell is if it is the earlier "McLaren" cast wheel like the one in the second pic or the later "MSW" wheel.
When looking from the LOGO side, the OUTSIDE loaders are wider nearest to the LOGO side.
The INSIDE loaders are widest at the base with sort of bulbous tabs. That cap stuck in your wheel is this style. She could never load from the outside.
So someone probably had the wheel off, put it back on without the cap and then said oh crap, then ended up pushing it in backwards from the front.
Gotcha.
or something like that, but I still understand you, don't mind me, been sick the last day or so.
Gotcha.
More like put the wheel one, didn't notice the cap was not flush and tried to pull it out only to push it in....and just left it that way. Or more likely, somebody tried to remove it and found that they have to take the wheel off and just left it.
