What kind of struts would you guys recommend for a '86 Vert McLaren?
My right front one is leaking on the the lower control arm.
Thanks Chris
Need help with what kind of struts to purchase
- capri50asc
Re: Need help with what kind of struts to purchase
I've always been fond of Koni, but the ride may be a bit stiffer than you wish. They are adjustable, but the softest is stiffer than stock.capri50asc wrote:What kind of struts would you guys recommend for a '86 Vert McLaren?
Thanks Chris
Monroe makes a fine line and they're made in the US (maybe even the Monroe, Michigan plant), at least last I looked.
ChuckG wrote:Monroe makes a fine line and they're made in the US (maybe even the Monroe, Michigan plant), at least last I looked.
I installed them on Scoutdrivinrebel 1986 ASC formally Hippys and Chris's 1988 ASC. And have them on my Cars. Great for normal driving. I also have been installing them at work for acouple of years and been very happy. NO combacks for ride or leakage problems.
If you need help or looking for someone to install LMK I can help.
- capri50asc
Thanks!!!!!!!
Thanks to all of you that provided good advise on which struts to purchase
for my '86 Vert
Thanks again Chris
for my '86 Vert
Thanks again Chris
- shelbyscarab
I can vouch for the Monroes. I like them. They provided the same stock performance as the originals.plumkrazy wrote:ChuckG wrote:Monroe makes a fine line and they're made in the US (maybe even the Monroe, Michigan plant), at least last I looked.
for Monroe's.
