How do I get the top down on my 1987 asc/Mclaren
Cantdothis1995
Ok so I left this car in my grandfathers will and it runs great, only problem is that I have no earthly Idea how to get the top down ok this vehicle and it bothers me greatly, if anyone could type up some instructions I'd be grateful, also could anyone tell me where the fuse boxes are?
- capri50asc
Lower your top
I have the manual for your top:
1) Firmly set the parking brake and shift the automatic transmission to PARK
2) Turn the ignition to ACC
3) lower the windows
4) sunvisors down
5) Press UP on the switch located behind the drivers seat (under where the seat belt retracks) This will release the tonneau cover and rear bow.
Hope this Helps
4) sunvisors down
Hope this Helps
birdiestobehad
Here are links to the actual operation manual. These can be found on the ascmclaren.com website, lots of wonderful information in the "service manual" section.
http://www.ascmclaren.com/diagrams/convert1.1.JPG
http://www.ascmclaren.com/diagrams/convert1.2.JPG
Good luck.
Good luck.
Terry M.
1986 'vert #118
1986 'vert #118
Top
I recently had a problem with my 88. There is a switch under the tonneau cove on the left side which was not made. The manual cable released the tonneau and then get to the switch to depress it.
