How do I get the top down on my 1987 asc/Mclaren
Cantdothis1995
Post by Cantdothis1995 »
Ok so I left this car in my grandfathers will and it runs great, only problem is that I have no earthly Idea how to get the top down ok this vehicle and it bothers me greatly, if anyone could type up some instructions I'd be grateful, also could anyone tell me where the fuse boxes are?
capri50asc
Lower your top
Post by capri50asc »
I have the manual for your top:
1) Firmly set the parking brake and shift the automatic transmission to PARK
2) Turn the ignition to ACC
3) lower the windows
4) sunvisors down
5) Press UP on the switch located behind the drivers seat (under where the seat belt retracks) This will release the tonneau cover and rear bow.
Hope this Helps
Chris
birdiestobehad
Post by birdiestobehad »
Here are links to the actual operation manual. These can be found on the ascmclaren.com website, lots of wonderful information in the "service manual" section.
http://www.ascmclaren.com/diagrams/convert1.1.JPG
http://www.ascmclaren.com/diagrams/convert1.2.JPG
Good luck.
Terry M.
1986 'vert #118
Top
I recently had a problem with my 88. There is a switch under the tonneau cove on the left side which was not made. The manual cable released the tonneau and then get to the switch to depress it.
tazslh
Post by tazslh »
I need to look at Hanks website a good bit more I see.Looks like he has loads of info available.
