Mesh Wheel Rub
Mesh Wheel Rub
Hi Guys,
I hope someone can help me here.
I finally got my 88 running, cleaned up and on the road, took it down to get inspected and they failed it for "tire rubbing" on the passenger side when turning right. I took it home and pulled the wheel and found that it was not the tire but the Mclaren mesh wheel rubbing on the lower A arm when turning hard right. There is a metal rub pad welded on the arm but it is still chewing up the wheel.
Is there an adjustable steeringstop or something that I can do to fix this. Obviously it has not been an issue tha last 20 years on this car and they are the original wheels (I think).
Thanks for any help
Chuck
Thanks for any help
Chuck
Not sure is there a chance it could have a bent tie rod? To make the wheel travel in to far.
-DAVID-
MY KEEPERS!
2003 SILVER MERCURY MARAUDER 320 HP 32V DOHC.
2013 FORD F150 RAPTOR "TERRAIN TAN" 4X4 CREW CAB & LIFT ON 37s.
2016 SHELBY MUSTANG GT-H HERTZ EDITION #82 OF 171.
1995 F-350 CREW CAB DUALLY POWERSTROKE FULL BANKS KIT!
MY KEEPERS!
These wheels on this car, right?
http://www.ascmclaren.org/phpBB/album_p ... pic_id=984
Boy, I have never heard them rubbing. They are too narrow to rub. I'm thinking you need somebody to take a look at it.
Have any other suspension parts been replaced?
Was the car in an accident? Maybe the K-member is off whack and causing the A-arm to be a bit off center?
Either way, a quick way to remedy the situation is with steering rack limiters. They are plastic C-clips that go on the inner tie rod (under the boot) that stop the wheels from turning so far. I needed to install some on mine after I put the 9" wide Cobra R's.
1988 ASC McLaren #709
Ok, take a step back and slow down. Ford put plastic C-clips on the rack and pinions in 1985 and up on the GT's/ Cars with 225-60-15 tires because of that problem. I bought some from Ford last year they are a couple of bucks.
Slid under car and find the bellows that cover the inner tie rods and remove clamps. Slid boot towards the outer tie rod and install plastic C-clips over the shiney bar. thats it and reinstall clamps. You dont need to get a alignment or even remove the tires.
I will try and find the part number again.
And if this is not it just add a couple till it dosnt hit then uninstall later
Mark hit this one on the head. They make simple little clips you put on the inner tie rod ends to limit the travel of the raack and pinion. I had to do this on my 79 RS because the Cobra R rims have about 6" of backspacing. I also have a bag of these clips somewhere in my garage. I will look for mine too, so either Mark or I should have it for you soon...
1979 Capri RS, you name it and it's been modified! Check out my website.
1985 Capri GPIV, currently under restoration.
1995 Eddie Bauer Bronco with minor mods...
2006 Yamaha YZFR1. 400lbs ~ 180HP!
~ Scott
~ Scott
I thought the C clips didn't come out until later and it was meant for the larger wheels. The small asc ones shouldn't rub even without the clips?
The C clips might "fix" the rubbing but I would not be 100% sure if that is the real cause.
LTDScott who sells suspension components wrote over at FEP:
Your mileage may vary I guess.The 91+ (I think) racks also had rack limiter clips installed to keep the bigger 16" tires on those cars from rubbing the suspension. They are approximately 2.25 turns LTL, but the ratio is the SAME! The rack limiter clips just take about 1/4 turn off for tire clearance.
Ahh That Clip
I got into the steering rack as was suggested, and what did I find on the opposite side of the rubbing tire-----a plastic C clip, but none was to be found on the other side. Hopefully I'll find a couple tomorrow and be back in business.
Thanks everyone for your help and suggestions!
