Idle-Surge
Idle-Surge
I have been trying to pinpoint a nasty case of Idle surge when I'm at a stop. it comes and goes but its getting to a point that If I'm at a Stop the RPM's Jump then the car stalls. Runs just fine while driving and there are days I dont have the issue but as of late it seems to be worse.
Any Ideas ? Could it be the IAC sensor going bad?
1986 White vert McLaren# 196
??? 4 U
Could it be the EFI going bad ??
- 86capriasc
Check out this site, you will have no problems figuring out your problem. Joel is a wiz, and great info from everyone over there.
http://sbftech.com/index.php?board=20.0
1986 ASCMclaren #108
stock E7 short block, explorer intake, 65mm TB, home built Gt45 turbo kit, 3.08s, Borla cat-back, '05 slot maf, Gt-40p heads, TFS1 cam, 80lb injectors, E85, Qaurterhorse tuner.
I can tell you exactly what it is, the Idle Air Flow Control. It sorta looks like a minature fuel pump, it will be up near the throttle body. They go wacky at times. Just swap a new one on and she will be happy again. You can probably grab one at any Upull it place as well. And, I have found one off a 2.3 works just the same. I had an Aerostar van with a 3.0 in it, it wanted one per year and also an Explorer, about every 18 months, not sure why. Anyhow, it just an 8mm socket and one snap on plug, can change this is less than 5 mins.
Hope that helps,
Hope that helps,
