An ascMcLaren forum for 84-86 Capri and 87-90 Mustang based cars modified by Automotive Speciality Corporation, a Division of American Sunroof Corporation. (no affiliation)
Drove her to work this past week and it rained. After looking the door over it looks like the window seal or felt is old and beat up. I found these on the fox restoration website would this fit on my Vert? I know I'm due to change the seals around the top but I'm hopinf if I replace these It will keep the door filling up with water.
1984-93 Conv Exterior Qtr Window Felt Set
Item # 1784001
Those appear to be for the 1/4 windows NOT the doors . The doors outer rubber which are often dry rotted/cracked are called DEW WIPES and Fox mustang does sell them and they cost like $89
Yep dew wipes are what you need for a standard mustang from what I know. The White 86 ASC coupe I picked up came filled with water that sloshed around when I moved the door. Be cautious with the old ones as you may want to re-use part of them.
Yea I see Fox Sells a Kit for the doors and convertible. Wouldn't hurt to just start replacing all of that as My top leaks as well. I want to replace the carpet at some point so I better knock all of this out first.
Havoc wrote:Yea I see Fox Sells a Kit for the doors and convertible. Wouldn't hurt to just start replacing all of that as My top leaks as well. I want to replace the carpet at some point so I better knock all of this out first.
Thanks for the help Guys.
If you have a convertible, just wait until you try to replace the weatherstripping that goes around the windshield frame and seals the top. I'm not sure who designed it, but I do believe there is an amusement park in Florida dedicated to him.
Shiny Side Up!
Bill
...it is their right, it is their duty, to throw off such government, and to provide new guards for their future security.
