0645
0647
Number: 0646
Date: Sun Mar 10, 2002 6:15 pm
Subject: Re: 88 McLaren
Just what I've seen regarding the rear ratios...
My 86 AOD McLaren also had the 3.27's spec'd on the door build
sticker. The 3.27's were the optional performance ratio from Ford for
automatic cars only. The 2.73's were standard in both auto's and 5spd
cars (non-Mclaren 5.0's), with the 3.08 being optional for the 5spd
and 3.27's for the automatic (In regards to 86-92 5.0's). The
automatic has a much lower numerical 1st gear than a 5spd and the
3.27 helps dramatically over the 2.73 gear. The 2.73 gear automatic
5.0's are pretty poky off the line. My old 88 McLaren 5spd had the
3.08 gear spec'd on it's door sticker as well. If they did make a
3.73 gear McLaren automatic, it would be a real snappy performer-
would have been a great idea with the AOD as it even has a lower
(numerically ) top gear overdrive than the 5spd stick and would make
the 3.73's acceptable at highway speeds.
Eric
--- In ascmclaren@y..., hanksgt <no_reply@y...> wrote:
> Sandy
> My '89 automatic has Ford installed 3.27 gears. I counted them and
> found it on the build tag.
> Hank
> Phoenix
> > This rear axle ratio is a "grey area". I do know that the 2.73:1
> was
> > standard equipment in the 5-Speeds, and that ALL cars with a D32
> code
> > (asc/McLaren Spec) that were 5-Speeds did get the 3.08:1 ratio.
> NOW,
> > according to asc/McLaren paperwork dated 1/'87 it states that
> > the "normal" rear axle ratio for an automatic 5.0L LX or GT was a
> > 3.23:1. It further states that D32 Spec Automatics would
receive
> AT
> > FORD the FORD AXLE RATIO of 3.72. Is it possible that this
didn't
> > REALLY take place? Yes, I guess so. Did it take place on SOME
> cars
> > and NOT OTHERS? Possible! Was it 1987s only? MAYBE!? Was it
> > planned, and not done? MAYBE. Perhaps yours was among SOME that
> did
> > not receive it?? Possibly!! I am not, never was mechanical, so
> > have never taken one apart as you have, and if I did, I would not
> > know what I was looking at, anyhow......so, I sure as heck I'm
NOT
> > doubting your intelligence, as I am sure you are correct. I am
> only
> > relating what I have found on asc/McLaren corporate work,
smuggled
> > out to me in the dead of night!! < grins >
> > S A N D Y
> > > I don't think they put 3.73 in the 88 automatics. The reason I
> say
> > > this is because I recently had to pull my rear apart to fix a
> leaky
> > > rear axle seal and leaky rear pinion seal, and while I was in
> there
> > I
> > > counted the teeth and came up with 36 on the ring and 11 on the
> > > pinion, and that truns out to be around 3.27 when you do the
> math.
> > > My rear has never been replaced, and these are the gears that
> came
> > > with the car origionally. I was just wondering if this is
> > correct.
> > > I may be wrong and have miscounted, I am just curious. Anyone
> with
> > > an answer, thank you for your help.
> > > Anthony
> > > ***bE oRiGiNaL***
> > > > Hello Anthony !
> > > > Some Rumor! No where close to 300HP, they do produce 225 H.P.
> > > > They DID "hop-up" the rear end! In 5-Speed cars the standard
> > rear
> > > > was 2.73 & they upped it to 3.08. In automatic cars standard
> was
> > > > 3.23 & they hopped it up to 3.73.
