0652    <<    Message Index    >>    0654
Number: 0653
Date: Mon Mar 11, 2002  6:49 pm
Subject: Re: 88 McLaren
AnThOnY:
Sometimes it's difficult, as the master listing of what was going to
be changed/altered does not always prove 100%. Further example: It
states that the braking system on the Coupes (asc/McLaren Mercury
Capri Hatchback Coupes of 1984, 1985 & 1986) was "modified" by the
addition of a "Brake Porportioning Valve" as well as Sintered
Metallic Heavy Duty Pads, replacing "Stock" equipment. This switch
was to be done BY asc/McLaren at the Livonia Avenue site. HOWEVER,
after printed material was printed (Including mention of this in the
Coupe sales brochure) asc/McLaren found out that if they TOUCHED or
ALTERED the braking system, they'd first have to crash test, under
government eyes the actual testing, and it had better conform to all
requirements and it better improve the stock system, and blah, blah,
blah. So, in the 11th hour, asc scratched the idea, and carried all
the valves to the dumpster. So, anyone reading the materials that I
have, or even just possessing the brochure, would swear it has these
items, when in fact...none ever did!!!
I think the 3:73:1 axle ratio in automatics might be the same scenaro!
-- In ascmclaren@y..., asc88mclaren <no_reply@y...> wrote:
> Thanks Sandy for all your help. I was just curious on this! I
just
> like to know about these things, it is very interesting to me. I
> really would have liked to have had the 3.73's!!! Quicker 0-60!!!
> Oh well, guess I'll just live with stock, or eventually change
them.
> But thanks again for all your help.
> Anthony
> ***bE oRiGiNaL***
> > This rear axle ratio is a "grey area". I do know that the 2.73:1
> was
> > standard equipment in the 5-Speeds, and that ALL cars with a D32
> code
> > (asc/McLaren Spec) that were 5-Speeds did get the 3.08:1 ratio.
> NOW,
> > according to asc/McLaren paperwork dated 1/'87 it states that
> > the "normal" rear axle ratio for an automatic 5.0L LX or GT was a
> > 3.23:1. It further states that D32 Spec Automatics would
receive
> AT
> > FORD the FORD AXLE RATIO of 3.72. Is it possible that this
didn't
> > REALLY take place? Yes, I guess so. Did it take place on SOME
> cars
> > and NOT OTHERS? Possible! Was it 1987s only? MAYBE!? Was it
> > planned, and not done? MAYBE. Perhaps yours was among SOME that
> did
> > not receive it?? Possibly!! I am not, never was mechanical, so
> > have never taken one apart as you have, and if I did, I would not
> > know what I was looking at, anyhow......so, I sure as heck I'm
NOT
> > doubting your intelligence, as I am sure you are correct. I am
> only
> > relating what I have found on asc/McLaren corporate work,
smuggled
> > out to me in the dead of night!! < grins >
> > S A N D Y
> > > I don't think they put 3.73 in the 88 automatics. The reason I
> say
> > > this is because I recently had to pull my rear apart to fix a
> leaky
> > > rear axle seal and leaky rear pinion seal, and while I was in
> there
> > I
> > > counted the teeth and came up with 36 on the ring and 11 on the
> > > pinion, and that truns out to be around 3.27 when you do the
> math.
> > > My rear has never been replaced, and these are the gears that
> came
> > > with the car origionally. I was just wondering if this is
> > correct.
> > > I may be wrong and have miscounted, I am just curious. Anyone
> with
> > > an answer, thank you for your help.
> > > Anthony
> > > ***bE oRiGiNaL***
> > > > Hello Anthony !
> > > > Some Rumor! No where close to 300HP, they do produce 225 H.P.
> > > > They DID "hop-up" the rear end! In 5-Speed cars the standard
> > rear
> > > > was 2.73 & they upped it to 3.08. In automatic cars standard
> was
> > > > 3.23 & they hopped it up to 3.73.
657 Re: 88 McLaren n20capri n20capri Mon  3/11/2002   6 KB
658 Re: 88 McLaren n20capri n20capri Mon  3/11/2002   6 KB
659 Re: 88 McLaren cigarsandy cigarsandy Mon  3/11/2002   7 KB
665 Re: 88 McLaren n20capri n20capri Tue  3/12/2002   8 KB
667 Re: 88 McLaren cigarsandy cigarsandy Tue  3/12/2002   8 KB
670 Re: 88 McLaren n20capri n20capri Wed  3/13/2002   9 KB
672 Re: 88 McLaren cigarsandy cigarsandy Wed  3/13/2002   10 KB
674 Re: 88 McLaren n20capri n20capri Wed  3/13/2002   11 KB
