0747    <<    Message Index    >>    0749
Number: 0748
Date: Mon Mar 25, 2002  5:48 pm
Subject: Re: [ASC McLaren ] Re: Dies when cold and idle.
My '86 EuroCoupe does this every time I start it cold. When I first got the
car and called Sandy to get it put on the registry, this topic came up and
he told me that it was normal with the "D32" cars because of the lager than
stock cam that was installed.
If I ever convert the car to mass-air this little "annoyance" would go away.
Brent----- Original Message -----
Sent: Sunday, March 24, 2002 1:15 PM
Subject: [ASC McLaren ] Re: Dies when cold and idle.> What year is your McLaren?
> If it's a convertible 86 or newer, probably the IAC valve needs
> cleaning or possibly replacement- fairly easy task. If you have a
> coupe, could be cam related as Sandy has found info on the coupes
> receiving the Motorsport cam.
> Eric
--- In ascmclaren@y..., noc_eng <no_reply@y...> wrote:
> > My McLaren has an unsteady idle when cold and dies if left alone.
> > I've heard of one other McLaren that has this same abnormality...
> or
> > maybe it is a normality. I'm thinking it is over-cammed.
> > Anyone else have the same experience nearly every time you start
> your
> > McLaren?
> > Dave
760 Re: Dies when cold and idle. cigarsandy cigarsandy Fri  3/29/2002   3 KB
766 Re: Dies when cold and idle. cigarsandy cigarsandy Fri  3/29/2002   3 KB
