1249    <<    Message Index    >>    1251
Number: 1250
Date: Wed Sep 18, 2002  7:29 pm
Subject: Leaks
Any convertible owners experience leaks from the hide away top cover
into the trunk? I just found a major problem. Recently I had to
replace the fuel pump dropped the gas tank (replaced tank too
because tray inside was sliding around) and discovered the trunk pan
was rotting through. Today brought it to an autobody shop lifted up
the spare and saw parts of the new gas tank. What a bummer. Now I
have to go over both rear quarters see were leak is starting,
replace trunk, undercoat, and repaint. I am going to have drain
holes made so this wont happen again.
-Nick
1251 Re: Leaks Sandy cigarsandy Wed  9/18/2002   5 KB
1252 Re: Leaks Marquis Grove InfoSysSec Wed  9/18/2002   6 KB
1254 Re: Leaks tasmaniac1 tasmaniac1 Thu  9/19/2002   3 KB
1262 Re: Leaks jdawg ecstacycustomz2000 Thu  9/19/2002   7 KB
1271 Re: Leaks asc709 asc709 Fri  9/20/2002   7 KB
1273 Re: Leaks Marquis Grove InfoSysSec Fri  9/20/2002   9 KB
1275 Re: Leaks jdawg ecstacycustomz2000 Fri  9/20/2002   10 KB
1253 Re: Leaks - How to seal the Spoiler Leaks if you have them... Marquis Grove InfoSysSec Wed  9/18/2002   5 KB
1263 Re: Leaks Ken Hughes cssmariner Thu  9/19/2002   7 KB
