1323
1325
Number: 1324
Date: Mon Sep 23, 2002 7:16 pm
Subject: Re: [ASC McLaren ] 84,85,86 Coupe "Sails"
Thanks! That is EXACTLY what I needed to hear :-)
> I have never removed the plexiglass inserts from my car, but I
have looked
> at them very closely and it appears that they are just held in
place with an
> adhesive of some sort, most likely 3M double sided trim tape.
> The original sail panel trim that was installed from Mercury is
still there,
> these inserts are just that, inserted in the three recessed area
on the sail
> panel that has horizontal lines molded into it.
> The only pieces in the rear quarter window area that are ASC
specific are
> going to be the large plexiglass piece the actually covers the
window and
> the three smaller plexiglass pieces that are "glued" to the O.E.
sail panel.
> I'm sure that these would be the only pieces that Hank would have,
not the
> actual O.E. sail panel.
> Brent
> To: <ascmclaren@y...>
> Sent: Monday, September 23, 2002 5:01 PM
> Subject: [ASC McLaren ] 84,85,86 Coupe "Sails"
> > On my coupe, my passenger side window "sail" (the styled 3
section
> > black plastic peice behind the rear window) is busted. I have in
> > place, a replacement taken out of another old coupe which is not
> > quite correct. It has the "grooves" in it. The ASC one had
these
> > plexiglass inserts in those sections to give it a nice "smooth"
look.
> > Question is, I can take the plexiglass inserts out of the old
sail
> > and "glue" them over the grooves of the new sail....but is that
> > correct? How was this done from ASC? Or do I need to just call
up
> > Hank and buy the whole part?
> > ascmclaren-unsubscribe@y...
