1346    <<    Message Index    >>    1348
Number: 1347
Date: Tue Sep 24, 2002  9:39 am
Subject: Re: [ASC McLaren ] '85 Carbs....
There is NO difference between a Mustang 5.0 and a Mercury 5.0 of the
same year, they are IDENTICAL. The only things different on these
cars are body parts and emblems. Mechanically and structurally they
are IDENTICAL, so if you are looking for a mechanical part for a
Capri tell them it's for a Mustang and you will have a much easier
time finding said part.
Tom S.
> It may have been the "same" but does it have the same part number?
> It appears that 84 carb part numbers started with E4 and 85 carb
> part numbers started with an E5.
> The carb that is on its way, supposedly has a part number stamped
on
> it of:
> E5TEZB C7A 5
> This would not have been on an '84 carb. And if I could decode it
> it probably says it is for a Ford application and not a Mercury one.
--- In ascmclaren@y..., James Gibat-Thoroski <jgibatthoroski@u...>
> > 84 and 85 had the same carb.
> > 76 Capri GHIA / 77 Capri RSX
> > http://www.mercurycapri.com .net .org
> > Updated September 3rd, 2002
> > ________________________________________________
> > Get your own "800" number
> > Voicemail, fax, email, and a lot more
> > http://www.ureach.com/reg/tag
> > ---- On Tue, 24 Sep 2002, negusm (negusm@y...) wrote:
> > > Anyone have the Ford/Mercury part number for the '85 Carb that
> would
> > > go on a Mercury Capri?
> > > I got a core from Ebay off from an '85 Mustang GT and just want
> to
> > > see if the numbers were "close".
> > > I got a Holley Carb ID book...but it seems to be missing a Ford
> > > number for 1985...it has one for the 1984 5.0L H.O.
> > > Not really looking for an exact match. I just would like to
get
> > > things a little closer to stock.
