1350
1352
Number: 1351
Date: Tue Sep 24, 2002 9:50 am
Subject: Re: LOOK
I have to back Nick up on this one!!
A friend of mine who raced and autocrossed his '89 GT wanted a
more aerodynamic look to the car swapped a capri bubble for his stock
hatch. The bubble fit perfectly except for a little work that was
needed to match it up to some LX taillights. The only difference
between the pre '83 and post '83 Capri body in the back is the rear
bumper cover assembly. The hatch opening is identical for Mustangs
and Capris from '79 thru '93. Thus a '93 Mustang could easily be
converted to a Capri body merely by changing the front and rear body
parts, the unibody is identical. Of course this is somewhat
simplified as there are minor year to year to year stamping,
structural, and detail changes.
In refering to the book entitled "The official Ford Mustang 5.0
technical reference and performance handbook" I found some references
to Capri body parts. On page 164 I found this in section "3.3
windows"--"The 1983-1986 Lincoln-Mercury Capri hatchbacks have a
unique "bubble-style" backlight, which led to the "bubbleback"
nickname popularly applied to these vehicles. (Since the early Fox-
body liftgates are interchangeable, the Capris' bubbleback glass
treatment is sometimes seen on custom Mustangs too.)"
Tom S.
--- In ascmclaren@y..., tasmaniac1 <no_reply@y...> wrote:
> > My God, I go out to dinner for 2 hours, and lookie here....all
> hell
> > breaks loose!! LOL
> Sandy next time you go out bring a laptop, lol.
> > 1. I swear to you all, on my deceased Mom's grave the plaques
> came in that bronze, with protection film over them & set into a
> black plastic piece, that formed a frame around them, and the
border
> was painted an orange-red.
> Wont go there.
> > 2. You cannot swap a Mustang Hatch for a Capri one because (run
> out & look at your car) the Capri one forms the rear fender peaks.
> When removed, your Capri has no rear fender peaks. Further other
> > deminsions are different! (and why would you want to? It would
> only serve to further establish in others minds that a Capri IS a
> Mustang! The beautiful bubble back is unique to the Capri, and the
> most striking feature.
> Capri's were more reminiscent of the old Porsche 944's with the
> fender flares and bubble back hatch. I just have to say Ford messed
> up this Capri Mustang mix and match Frankenstein shop in the first
> place. Do you remember the JBA Edition Mustang? It was a test mule
> that was highly publicized late 80's early 90's. It was a Mustang
> with a Capri style bubble Hatch and even wider fender flares.
> > 3. The 3 triangular smoked black plexiglass pieces just
rearward
> of
> > the side 1/4 window were glued on with some yellow-ish sticky
> glue.
> > Most (or many) fell off in car washes with the huge spinning
> vertical
> > wheels caught them & ripped them off!! Even if you're drying
your
> > car, an edge of a towel can get caught under the sharp edge and
> pull
> > it off. If you dry your car as I do, with a lawn & leaf blower,
> > power of the unit can literally blow one of these things flying
> off the car.
> Mine came off when I bit into a peppermint patty, just kidding.
> -Nick
