1387
1389
Number: 1388
Date: Fri Sep 27, 2002 10:10 am
Subject: [ASC McLaren ] Re: CarFax
What is a "5L" car?
> Hmmmm, so to completely whip a dead horse....
> Was there any other option that the 5L engine in 1985? I've looked
> everywhere on the net and only see the "M" engine code. This would
> explain why I haven't found any 6 cylinder Capris in CarFax....I
> guess Sandy was completely right, the data is probably no longer
> available.
> What was interesting is seeing how many records each car
had....some
> cars had 9 or more records in CarFax and they were kindof grouped
> together.
> I tested 10000 vins last night and every one came back as a 5L car.
> > Well, I wrote the program which kind of prodded through the
> > Vins...it never found anything but 5L cars...I think car fax will
> > accept any correct vin, provided the "check" digit in the vin is
> > correct (digit 9).
> > For giggles sake, I toyed with it until I figured out the algo
for
> > the "check" digit. It is simply a BASE 11 number with X
> > being "10"...0,1,2,3,4,5,6,7,8,9,X...and it is calculated off
from
> > the last 6 digits of the VIN. Lets say your Vin ends in:
> > 607867
> > You would take the first number "6" and multiply it by 7 subtract
> > one and divide by 11 and take the remainder. This is Value 1.
> > You then take "0" multiply it by 6, add to Value 1, divide the
> > result by 11 and take the remainder. This is Value 2.
> > You then take "7" multiply it by 5, add to Value 2, divide the
> > result by 11 and take the remainder. This is Value 3.
> > You then take "8" multiply it by 4, add to Value 3, divide the
> > result by 11 and take the remainder. This is Value 4.
> > You then take "6" multiply it by 3, add to Value 4, divide the
> > result by 11 and take the remainder. This is Value 5.
> > You then take "7" multiply it by 2, add to Value 5, divide the
> > result by 11 and take the remainder. This is Value 6.
> > Value 6 is your check digit, unless it is 10 then it is "X"
> > Here is some quick VB code that figures it out:
> > Dim digit As String
> > Dim num As String
> > num = Right(sText, 6)
> > digit = (Mid(num, 1, 1) * 7 - 1) Mod 11
> > digit = (digit + Mid(num, 2, 1) * 6) Mod 11
> > digit = (digit + Mid(num, 3, 1) * 5) Mod 11
> > digit = (digit + Mid(num, 4, 1) * 4) Mod 11
> > digit = (digit + Mid(num, 5, 1) * 3) Mod 11
> > digit = (digit + Mid(num, 6, 1) * 2) Mod 11
> > If digit = 10 Then
> > digit = "X"
> > End If
> > Yeah, I was bored...
> > Carfax barfs on everything except the correct check digit.
> > > Mike,
> > > Just an FWI on getting a reports from CarFax on Capri's.
> > > I know of several people that have run '85 Capri RS's and '86
> > Capri 5.0L
> > > cars through CarFax and it reports that they are GS trim cars.
> > > If you were able to write a program to search their site
looking
> > for just
> > > the V8 equipped cars and catalog the vin's in a spreadsheet, I
> > believe that
> > > you might be the only one to do so.
> > > Brent
> > > ----- Original Message -----
> > > From: "negusm" <negusm@y...>
> > > To: <ascmclaren@y...>
> > > Sent: Thursday, September 26, 2002 10:49 AM
> > > > Which list? The list of 1985 vins of ASCs, or the list of
1985
> > vins
> > > > of Mercury Capris?
> > > > Carfax obviously has the master list (or a damn near complete
> > one) of
> > > > VINs of the 1985 Mercury Capris. Putting in VINs that are
> > slightly
> > > > incorrect as far as engine code, prompts you that it is a
close
> > match
> > > > to another code which is correct. Now this will not tell you
> > whether
> > > > your car was an ASC but it will give you an idea as to what
> ford
> > made.
> > > > -Mike
> > > > > I have the list you speak of, but only for 1986. The 1985
> > listing
> > > > > was shredded, and no longer exists.
> > > > > > So I ordered a history report from car fax. It didn't
> really
> > > > tell
> > > > > me
> > > > > > much I didn't know, except the police report where the
car
> > was
> > > > hit
> > > > > in
> > > > > > Florida. I wonder if you can get an old Police report
from
> > > > > > report number....
> > > > > > So I started messing around on the site and putting in
> > various
> > > > made-
> > > > > > up VINS...one off from my own and it looks like all the
> cars
> > were
> > > > > the
> > > > > > same build type, 5L standard, etc....
> > > > > > I then wondered if I should write a program to check all
> > VINS
> > > > > > against carfax and get a complete list of all the VINs
for
> > 1985
> > > > > > coupes that had that engine/tranny/body combination.
> > > > > > Would that list be at all helpful? I'm not sure that it
> > would.
> > > > I
> > > > > > bet there would be thousands of VINS...
> > > > > > what would be interesting is to see where these cars fell
> in
> > > > > > production run...whether they were grouped or randomly
> spread
> > > > out...
> > > > > > or maybe there is an easier way to get the list...I know
> > carfax
> > > > > > obviously has it.
> > > > > > -Mike
> > > > To unsubscribe from this group, send an email to:
> > > > ascmclaren-unsubscribe@y...
