1677
1679
Number: 1678
Date: Mon Nov 11, 2002 3:43 pm
Subject: Re: Re: [ASC McLaren ] Air cleaner details....
Mine was from an 83 I believe.
http://www.mercurycapri.com/projectrsx/ur-rsx/images/rsxrclnr.jpg
76 Capri GHIA / 77 Capri RSX
http://www.mercurycapri.com .net .org
Updated November 4th, 2002________________________________________________
Get your own "800" number
Voicemail, fax, email, and a lot more
http://www.ureach.com/reg/tag---- On Tue, 5 Nov 2002, Brent Abrams (babrams@l...) wrote:
> Mike,.
> The '84-'85 air cleaner decal had the black lettering only.
> It read either "5.0 Liter EFI HO" if you had a CFI fuel injected car or "5.0
> Liter 4V HO" if it was carbureted.
> Previously in '83 was when the air cleaner decal had the black stripe in a
> circle around the air cleaner top with the clear letters (letting the
> aluminum shine through) reading "5.0 Liter 4V H.O."
> '82 was the same style decal as '83 except it read "5.0 Liter H.O." (no
> 4-barrel carb until '83)
> Obviously the '82 & '83 information does not apply to a McLaren but I
> figured the info might be useful in explaining when the different decals
> were used so you can rule out the one's that aren't correct.
> Brent
> Sent: Tuesday, November 05, 2002 11:03 AM
> Subject: [ASC McLaren ] Air cleaner details....
> > By the time my 1985 coupe got to me, the air cleaner was loooong
> > gone. I have managed to get the entire setup but am curious as to
> > the decal on the air cleaner cover.
> > I have seen a black stripe all the way around it with "5.0 Liter HO"
> > and a simpler "5.0 Liter HO" in black with no black stripe.
> > Which is correct? I have seen both advertised for 1984 and 1985 and
> > 1986......I thought the black stripe was before 1985.
