1713    <<    Message Index    >>    1715
Number: 1714
Date: Wed Nov 20, 2002  8:59 am
Subject: Re: 1985 Coupe Rearend
I also read on a cougar site that there may be a tag attached to the
rear as well.
http://www.coolcats.net/tech/general/axleinfo.html
the axle tag, attached to the lower lefthand bolt on the rear axle
itself. The bottom left line will give you the gear ratio, and the
type of rear end (S for limited slip non-locking, and L for locking). -Mike
--- In ascmclaren@y..., tasmaniac1 <no_reply@y...> wrote:
--- In ascmclaren@y..., "Tom S." <tkm654@c...> wrote:
> > 8.8 was put into use for 1986.
> > Tom S.
> Yes you are right!
> -Nick
