1839    <<    Message Index    >>    1841
Number: 1840
Date: Thu Dec 19, 2002  8:00 pm
Subject: Re: Anyone ever dyno their cars?
Hey Mike thanks for all the great advice. I will check everything I
could over the weekend and once the shop opens back up after
Christmas I will look into the rest.
Maybe we can get together in the spring and and take some pictures
of the cars or hit Englishtown. Better yet maybe we can get a little
get together with other group members as well for a little ASC
MClaren picnic. Any takers?
Ciao, Nick :)
> Nick,
> Well it seems like everything so far is cool. The 155 pump is
good
> for now with 6psi. The wires are good too. I think once you get
> A/F ratio and timing checked you'll be on track HP wise. Like I
said
> before, I'd get a good ignition and a bigger capacity fuel pump
for
> the future though. ALSO, I'd use spark plugs that are one heat
range
> colder than stock and gap them at .035 instead of .050 so there is
no
> chance the flame gets blown out...that along with the ignition
you'll
> be in great shape. Again, hope this helps and good luck!
> Talk to you later,
> Mike
--- In ascmclaren@yahoogroups.com, tasmaniac1 <no_reply@y...>
> > Hi Mike,
> > I printed out what you wrote to double check somethings. Here is
> > some more input. The fuel pump I am using is a 155lph which was
> > recommended for the 6psi. I will definately go up to either the
190
> > or 255lph when I have the trunk pan replaced and also put on a
9lb
> > pulley too. I also put in a new fuel pressure regulator, 9mm
wires
> > and new plugs. Timing should be checked as well as the air to
fuel
> > ratio you mentioned. The rewiring job is really getting to me.
> After
> > Christmas when the shop is open again I will talk to him about
> > changing it. Thanks for all your help and will keep you posted.
> > -Nick
> > > I wouldn't worry too much. It did pick up 52 horsepower. It
> only
> > > sounds off about 20HP, and I think that is very very easily
> gained
> > by
> > > some tuning. When they dynoed it, did they check your air fuel
> > > ratio? For a blower car you should see 12:1 to 12.5:1 and for
> > > naturally aspirated you should see 12.8:1 to 13.2:1. These
are
> > safe
> > > numbers. Maybe your A/F is off. I noticed your using 24#
> > injectors
> > > but what fuel pump are you running? (I'd think at least a
190lph
> > > unit if not a 255lph) Also, maybe the re-wiring job is causing
> > some
> > > problems. I don't know I'm just throwing out ideas. A friend
of
> > > mine just did heads and cam on his blower car and it was
running
> > like
> > > crap. The first problem was he had the rocker arms adjusted
way
> > too
> > > tight. The second problem was he had the wrong spark plugs in
> > > car. They were to short, once he put the right ones in the
car
> > ran
> > > fine. (He had AFR heads so if you make the swap make sure to
get
> > > right plugs...lol) Also, what ignition are you running. A
stock
> > > ignition might not be able to handle the extra fuel and
spark.
> > I'd
> > > definitely invest in a Crane or MSD unit with a timing retard
> > > feature. Check the timing too. I'd think 10-13 degrees is
where
> > you
> > > should be...again tuning will help you achieve the best
advance.
> > If
> > > I think of anything else I'll post it. Hope this helps and
good
> > > luck...keep me posted.
> > > Mike
