2047    <<    Message Index    >>    2049
Number: 2048
Date: Thu Feb 20, 2003  12:21 am
Subject: Re: 85 Coupe Speedometer
My '85, 607910, had an 85 mph speedo with no evidence of having
ever been changed. My guess is your car had a 3.08 rearend and has
been changed to 2.73 or the tire size has gone from the 225/50 tires
originally installed to a 225/60 which could also cause the
difference that you noted. Different transmissions could also
explain your difference. Just changing the speedo head would not
make a difference in noted speed.
Your door tag will identify what axle ratio was installed from the
factory. A 2.73 Traction-Lok will have a code of "M" and a 3.08
Traction-Lok will have a code of "Z". A tag attached to the rear
cover of the differential will have a code of 2L73 for a 2.73 and a
code of 3L08 for a 3.08 ratio.
Tom S.
<negusm@y...> wrote:
> The 1985 coupes were supposed to have 140MPH speedos, right? Mine
> has the 85MPH variety but has always been 7-8MPH off (registers
too
> low, I have to add 7-8mph to get the right speed).
> I'm wondering if the 85 speedo is definitely wrong, which is odd
> me since why would anyone replace a 140 with an 85 or its
possible,
> the 85 speedo is right, but I have the wrong rearend gears. We
> never found a tag on the rearend to tell us what was supposed to
be
> in there...I have a feeling that the previous owner who raced it a
> little, may have switched gears (or kept the 140MPH speedo?).
> We had to replace the rearend gears because they shredded but we
> can't remember exactly what went back in. I beleive it was the
same
> as that were in it since the speedo discrepency didn't change.
> Would higher or lower gears make the reading go + or -?
> I bought a Ford 140MPH speedo to go back in this car and figured
> that I would get the speedo gears all worked out so it read right
> but its always been an odd curiosity I have never solved.
> When I get back up there I'll talk to the previous owner and ask
him
> if he fiddled much with the car. He only owned it a short time
> after buying it from Florida before he moved on to (or fell in
love
> with) SVOs.
2049 Re: 85 Coupe Speedometer negusm <negusm@y...> negusm Thu  2/20/2003   4 KB
