2241    <<    Message Index    >>    2243
Number: 2242
Date: Fri Mar 28, 2003  10:18 am
Subject: Re: Upgraded Suspension and eBay 83!!!!!
From what I can see the car reeks of being an 85.
The side mouldings look'85?
The washer resevoir is '85 (did they have that style back in 83?) At
least the low level sensor would be on the top of the washer resevoir
which it isn't.
The dash has the grey "faux bolt" panels on it for 1984-1986.
> I have no comment on this one. Look at the pictures very, very
> carefully
> > Hey there, welcome to our little piece of the net. My driver side
> > rear sages horribly, so if the springs are the same for the
Stangs,
> I
> > would be interested in yours. I had the same problem finding a
> spring
> > compressor for these springs to, made another verson work.
> > Also, I got into a discussion on another board about this. Very
> > interesting car. However, some things are wrong, even if it IS a
> > prototype. I would say it is, since the Carfax says it is indeed
an
> > 83. There are some things wrong though. The door panels are 87up.
> The
> > wheels are 87up. The hood is from a Turbo RS, as it even has the
> > factory cutout underneith. The seats are recovered or wear seat
> > covers. The dash appliques are standard stang or capri, and the
> > designed by plaque is on the dash. Also, why is the entire dash
> > black? Obviously the ground effects are not the production pieces
> for
> > 84-86. The strut tower brace as well. Sandy any insight on the
> color?
> > Now I realize, being an 83 would make it a prototype I would
think,
> > so maybe things like the hood, strut tower brace, or dash
appliques
> > came factory, but I doubt it. I emailed him with several
questions,
> > so I will let you know what he says.
> > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
> > ViewItem&item=2409018374&category=6236
> > > Hi All
> > > Mostly a lurker here.
> > > I thought it was time (at 128,000 miles) to upgrade the
> suspension.
> > > Koni red shocks and struts with Motorsport B springs. I used
> > > polygraphite spring isolators and sway bar links. Found out the
> > hard
> > > way that Fox body cars require a special plate type spring
> > > compressor. Couldn't find one anywhere in Phoenix. Called a
> friend
> > > in the business and borrowed his.
> > > Got it aligned this morning and it rides and handles great.
> > > My wife is upset at all the 'old' parts laying around the
garage.
> > > Should I keep the old shocks and springs?
> > > Next to go in: Ceramic disc pads from raceparts.com and braided
> > > brakes lines. Then the polyurethane motor mounts. Then the
brand
> > new
> > > Ford posi unit, axles and 3.27 gears. All the parts are here,
> > > waiting to get time to install.
> > > Anyone in AZ going to the Tucson Mustang show this weekend or
> > > Copperstate Mustang Club show April 5th?
> > > Keep up all the info sharing, its great.
> > > Hank
> > > Phoenix, AZ
> > > '89 ASC #176
2244 Re: Upgraded Suspension and eBay 83!!!!! negusm negusm Fri  3/28/2003   5 KB
