2529    <<    Message Index    >>    2531
Number: 2530
Date: Tue May 6, 2003  11:45 am
Subject: Re: Part II ~ EXTERIOR
Visable from the outside of the car, there are no screw heads. This
strip smooths over the area where the front & rear ascMcLaren added
pieces meet the stock Capri bumper fascias. They appear to be glued
on. They are pretty much flat (the rear one) and ribbed (front).
Yjey are both curved like this: ) (Convex) and were at one time
flexable. The rears are body colored, the fronts (thicker & harder
material) are black. I have not a picture that shows this detail.
> Hey Sandy, you had mentioned that rear valence finishing strip to
me
> before, and I am still baffled. My rear valence is affixed with
> several screws from underneith. Was this the way they were supposed
> to be installed, or was it more like the front valence, with screws
> around the outside edge? I can not discern any strips on the pics I
> have, but that doesn't mean that they are not there. You have a pic
> of your car with that strip? Thanks
> > Okay, here we go with Part II, the Exterior (remember 1985-1986
> > Coupes). (Excluding EuroCoupe).
> > * ascMcLaren Specific Lower Front Air Dam with HELLA {brand} Fog
> > Lamps, wired to stock RS under dash mounted switch-gear.
> > * ascMcLaren logo decal applied to hood buldge, off center to
left.
> > * Above deleted for 1986, replaced by a chrome ascMcLaren emblem
> > affixed over the "mercury" emblem in between grille bars.
> > * ascMcLaren specific side lower ground effect skirting.
> > * ascMcLaren rear under bumper valance panel with exhaust pipe
> > cutouts.
> > * Color-Keyed finishing moulding at rear, between rear valance &
> > stock bumper.
> > * Black finishing moulding at front, between air dam and stock
> bumper
> > * Side rear quarter air management window appliques in dark
lexan
> > plastic to cut down wind turbulance and streamline air flow.
> > Triangle appliques set into unique ascMcLaren frame rails.
> > * Mock Air Vent blackened appliques affixed to 3 mock air-vents.
> > * Side Rear Quarter Appliques omitted when ordered with T-Tops.
3
> > triangle mock air vent appliques remain with T-Top.
> > * Light Smoke Lexan Plastic Headlamp & Taillamp Covers with
rubber
> > weather-stripping mouldings.
> > * Rear Deck-Lid "Whale-Tail" spoiler of moulded injection hard
> > rubber. Color Keyed on certain colors. TBD (means: To Be
> Decided).
> > * 360-degree accent tape stripe on all lowest edges of vehicle,
> > encircling front air dam, side skirting, & rear under bumper
> valance
> > panel. (Omit on Oxford White Cars !) Colors:
> > Popsicle Orange; Raven Black; Platinum Silver.
> > * Matching color rear Hatch decal logo on right-side, over
> taillmap.
> > * Mid-Bodyside above side moulding McLaren-Style decal stripe
from
> > side door to rear, around rear under taillamp to oppisite side
> > forward to door. Both sides end with ascMcLaren logo decal.
Same
> > colors as above. (Note: This was installed on Oxford White
cars).
> > S A N D Y
