2588
2590
Number: 2589
Date: Thu May 8, 2003 9:28 pm
Subject: Re: [ASC McLaren ] Part II ~ EXTERIOR
ok the correct way for a oxford white coupe is no lower orange stripe....
(currently no striping on the car)
when jacques got his car, has the orange striping kit needed, but includes the bottom
previous owner got new striping from
paradise automotive in odessa fl...
just gathering all the information to put the car back together right..
cheers
david and jacques negrey
86 Coupe Automatic #38
Sent: Tuesday, May 06, 2003 2:37 PM
That is correct, Brent. No lower stripe kit on Oxford White cars,
only the upper stripe kit. White cars ALSO had matching white
wheels, but we'll get to THAT on another day.
> Sandy,
> Just so I understand if I read this correctly, Oxford White Coupes
did not
> get the extreme lower tape stripe that was applied to the ground
effects?
> Brent
> From: "Sandy Block" <cigarsandy@c...>
> Sent: Tuesday, May 06, 2003 10:52 AM
> Subject: [ASC McLaren ] Part II ~ EXTERIOR
> > Okay, here we go with Part II, the Exterior (remember 1985-1986
> > Coupes). (Excluding EuroCoupe).
> > * ascMcLaren Specific Lower Front Air Dam with HELLA {brand} Fog
> > Lamps, wired to stock RS under dash mounted switch-gear.
> > * ascMcLaren logo decal applied to hood buldge, off center to
left.
> > * Above deleted for 1986, replaced by a chrome ascMcLaren emblem
> > affixed over the "mercury" emblem in between grille bars.
> > * ascMcLaren specific side lower ground effect skirting.
> > * ascMcLaren rear under bumper valance panel with exhaust pipe
> > cutouts.
> > * Color-Keyed finishing moulding at rear, between rear valance &
> > stock bumper.
> > * Black finishing moulding at front, between air dam and stock
bumper
> > * Side rear quarter air management window appliques in dark lexan
> > plastic to cut down wind turbulance and streamline air flow.
> > Triangle appliques set into unique ascMcLaren frame rails.
> > * Mock Air Vent blackened appliques affixed to 3 mock air-vents.
> > * Side Rear Quarter Appliques omitted when ordered with T-Tops.
3
> > triangle mock air vent appliques remain with T-Top.
> > * Light Smoke Lexan Plastic Headlamp & Taillamp Covers with
rubber
> > weather-stripping mouldings.
> > * Rear Deck-Lid "Whale-Tail" spoiler of moulded injection hard
> > rubber. Color Keyed on certain colors. TBD (means: To Be
Decided).
> > * 360-degree accent tape stripe on all lowest edges of vehicle,
> > encircling front air dam, side skirting, & rear under bumper
valance
> > panel. (Omit on Oxford White Cars !) Colors:
> > Popsicle Orange; Raven Black; Platinum Silver.
> > * Matching color rear Hatch decal logo on right-side, over
taillmap.
> > * Mid-Bodyside above side moulding McLaren-Style decal stripe
from
> > side door to rear, around rear under taillamp to oppisite side
> > forward to door. Both sides end with ascMcLaren logo decal. Same
> > colors as above. (Note: This was installed on Oxford White
cars).
> > S A N D Y
the Yahoo! Terms of Service.
