2598    <<    Message Index    >>    2600
Number: 2599
Date: Fri May 9, 2003  11:06 am
Subject: Re: [ASC McLaren ] Re: Ready? E N G I N E !!!!!!!!!!
I find that a little confusing also.
Starting in 1985, Ford began using stainless-steel tubular "headers" on 5.0L
4-barrel T-5 equipped cars. Early CFI/AOD cars came with carryover cast iron
exhaust manifolds that were used on the '84 cars but later in '85 these were
switched over to the same tube-header as the T-5 cars got.
>From 1986 on all 5.0L equipped cars came with the stainless steel tubular
headers.
Anyone familiar with the production tubular header knows that although they
were an improvement over the cast iron manifolds, they were very restrictive
at the bolt flanges. It was crimped down for clearance for the production
line crew to be able to attach the header with their torque guns easily
during assembly.
Brent
Sent: Friday, May 09, 2003 9:32 AM
Subject: [ASC McLaren ] Re: Ready? E N G I N E !!!!!!!!!!> Do you have the part number for that stainless exhaust header?
> Does anyone have that on their car?
> I need to check my car and see what's on there now.
> > Sorry, I left it off. According to the paper, all done by FORD
> under
> > D32 code.
> > > Were these changes all done by ascMcLaren or by Ford, or doesn't
> it
> > > say?
> <cigarsandy@c...>
> > > wrote:
> > > > I have a little UNexpected time this AM,so lets go tackle the
> > > final
> > > > section: ENGINE.
> > > > * Replace Rocker Arms to Increase Usabe Rev Limit to 7000
> RPM.
> > > > (Power Gain of 5%).
> > > > * Upgrade Exhaust Header (Stainless Steel) Internal Mandrel
> Bent
> > > to
> > > > include Exhaust Port Liners to be tuned with lower restriction
> > > > exhaust.
> > > > * Tuned Muffler to Reduce Back-Pressure & Enhance Exhaust Note.
> > > > * Prototype Valve Springs & Prototype Valve Guides
> > > > * B-303 Ford Motorsport Hi Po Cam
> > > > Now, before you hop all over ME, keep in mind that I am just
> > > copying
> > > > from ascMcLaren Internal "FINAL MEMO" Pre-Job1 Program. Again,
> > > this
> > > > was to apply ONLY to 1985/1986 Full Packaged Coupes, which
> covers
> > > 150
> > > > 1985s & 115 1986s, for a grand total of 265 cars.
> > > > S A N D Y (adorning a Hard Hat !!)
