2727    <<    Message Index    >>    2729
Number: 2728
Date: Fri May 23, 2003  4:23 am
Subject: Re: What's lost is now found...
"I guess TR would stand for transmission but "2BBBB" seems
like an odd code for a tranny."
2 indicates 5 speed '84-'87, W would indicate 5 speed for '88, and a
T would indicate an aod automatic for '84-'92.
The BBBB part I have yet to decipher, most mustangs I've seen are
like my '89 ssp coupe where it is 2PPSS. I haven't seen all 4
letters the same. I have seen reference to the letters also being
spring codes, can't verify.
Tom S.
> F0032 is for the front spring code.
> R0073 is rear spring code.
> 236780 is the dso code, normal car would be 2 digit but since ASC
> special ordered the car dso is 6 digit. First 2 numbers are sales
> district last 4 are for the special order. Your sales district is
> 23 which is Memphis. If you can, post a pic of the label.
> Tom S.
> > Oh and one more item...
> > What do the three DSO codes mean? I figure that the first is
for
> > the special build (F0032) to get the right color but what are
> > other two for? "R0073" and "236780"
> > > OK, I looked at info for the Mustang GT and I see how things
> > should
> > > line up.
> > > XP is the color code. For Mustangs it looks to be a two tone
> > option.
> > > AC is blank and the R has a Y value for Radio Delete.
> > > The tranny decodes to 3 values. 2 is 5 speed manual. BB and
BB
> > > represent codes for front and rear springs.
> > > > Actually I thought about where the paint color should show
up
> > and
> > > > next to "XP" there is "Exterior Paint Colors". Was "XP" a
> mark
> > > for
> > > > a "special color" order? Much like the first gen Mustangs
> > having
> > > > an "X" for their color code when they got painted a Tbird
> color?
> > > > So like who's to say this car wasn't white? Or were white
> > coupes
> > > > ordered normally since white could be gotten on the RS (5.0)
> as
> > > well
> > > > as the GS? This car was probably built too early anyways to
> be
> > a
> > > > white one.
> > > > Also, is there anyplace where it should say what COLOR the
> > > exterior
> > > > of the car should be. The code is 3L for blue but not found
> > > > anywhere on the tag.
> > > > Typo for Front GAWR...should be 3131LB
> > > > -Mike
> > > > > I found the paper door tag for my car...nasty looking but
> > still
> > > > > readable.
> > > > > Here is what it BARELY says...
> > > > > Date: 01/85
> > > > > Front GAWR: 131LB/966KG
> > > > > GVWR: 4060LB/1841KG
> > > > > REAR GAWR: 1949 LB/884 KG
> > > > > VIN: 1MEBP79M1FF607872
> > > > > Type: PASSENGER
> > > > > XP
> > > > > DSO: F0032
> > > > > R0073
> > > > > 236780
> > > > > Body: 61D
> > > > > VR: <blank>
> > > > > MLDG: <blank> (however maybe XP?)
> > > > > The XP that is beneath "PASSENGER" for "Type" is directly
> > above
> > > > > MLDG. Maybe it was put on the wrong line?
> > > > > Int. Trim: PA
> > > > > There is a Y half way between "A/C" and "R". My guess
would
> > be
> > > > that
> > > > > the Y is YES for A/C.
> > > > > There is an M half way between "S" and "AX". My guess is
> that
> > > it
> > > > is
> > > > > for the axle. (poop, I was hoping for the 3.08 and not
> > 2.73)
> > > > > TR: 2BBBB
> like
> > > an
> > > > > -Mike
