2781
2783
Number: 2782
Date: Wed May 28, 2003 1:02 pm
Subject: Re: [ASC McLaren ] electrical problem
I am not sure how they are wired, but if they are wired through the
headlight switch...where you can't turn on the foglights without the
headlights being on and the foglights get thier power through the
headlight switch...the headlight switch is probably overheating.
I had this problem when I added a bunch of extra lights to my 81
Capri. I had an extra bulb in each taillight then I had wired it so
when the low beams were on, so were the high beams, only the highbeams
were quite a bit dimmer than the low beams.
With all that extra voltage/wattage going through the switch eventually
it would kill the lights...then bring them on, then off, on, etc. etc.
because the headlight switch was overheating.
Try a new headlight switch.
76 Mercury Capri GHIA / 77 Mercury Capri RSX
http://www.mercurycapri.com
Still working on it!
Date: Wednesday, May 28, 2003 12:31 pm
Subject: [ASC McLaren ] electrical problem
> has anyone experienced this?? 2 issues
> 1.I turn on my fog lights and for about 15 min their fine...after
> that, they make my head lights blink on & off .its like the car is
> possessed or something. I turn them off and my headlights are normal
> again.
> 2.another issue is when i hit the horn on the car .....it works for
> about 2 sec. and the blows a fuse.wierd huh.
> I ran into another Mclaren owner and he had the same exact problem.
> iam gonna be putting in a coil over kit this weekend and since Iam
> gonna be under their I might as well fix these issues.
