2788
2790
Number: 2789
Date: Wed May 28, 2003 1:44 pm
Subject: Re: [ASC McLaren ] electrical problem
Here is the text, in case the URL is "hacked up" by your email reader:
In the February, 1991 edition of Popular Mechanics, the "Car Clinic" by Mike
Allen had the following:
Fogged Out
"I have a 1988 Ford Mustang GT. After about 20 minutes with my headlights and
fog lights on at the same time, the headlights blink intermittently."
Victor Alberico
Watertown, MA"I rarely find the answer to a Car Clinic problem covered in a TSB, but every
now and then...
Ford TSB 89-17-11 says this is caused by overheating in the headlamp circuit.
It's a phenomenon affecting '83-'89 Escorts, '83-'87 EXPs and '87-'88 Mustangs.
You'll need to replace the headlamp and dimmer switches, several connectors,
then bypass the wiring in the circuit with new 12ga wire run alongside the
original harness. It's supposed to take 1.3 hours for a service technician to
do this, and you ought to see if the dealer will still do the repair under
warranty."
Nelson
1990 Mustang LX 5.0
http://fiveoh.homestead.com
> has anyone experienced this?? 2 issues
> 1.I turn on my fog lights and for about 15 min their fine...after
> that, they make my head lights blink on & off .its like the car is
> possessed or something. I turn them off and my headlights are normal
> again.
> 2.another issue is when i hit the horn on the car .....it works for
> about 2 sec. and the blows a fuse.wierd huh.
> I ran into another Mclaren owner and he had the same exact problem.
> iam gonna be putting in a coil over kit this weekend and since Iam
> gonna be under their I might as well fix these issues.
