3024
3026
Number: 3025
Date: Sun Jun 22, 2003 9:46 pm
Subject: Re: Anes ebay Air horns
Just to be safe, make sure you ask the seller if everything in the
box looks exactly as the picture ON the box. I did see one "Anes"
set with a different compressor than what was shown on the box.
However, that set was a different Anes model than what what I posted.
> Eric, first off, give me a call. I lost your phone # again!!!
> Yes, they can be added and there is a set on e-bay right now!
1987s
> had them and when you come over, I'll let you see the exact
location
> where they went by looking at my '86 McLaren, so you can copy it.
--- In ascmclaren@yahoogroups.com, ho660 <no_reply@y...> wrote:
> > Has anyone added these to a later year McLaren? I'm going to
miss
> not
> > having it in the 89 as my 86 did have it.
> > Regards,
> > Eric
> > > When you put the "Stebel Junior" compressor next to
the "Anes",
> > they
> > > appear identical except for the little yellow oil inlet at the
> top
> > > of the "Anes". I guess you put some compressor oil in it once
> and
> > a
> > > while to keep it lubricated. Since there are internal
spinning
> > > parts. I think the Anes is an older version (1981). Most
likely
> > > made by the same company. They probably fixed the bearing
inside
> > > which required lubrication.
> <cigarsandy@c...>
> > > wrote:
> > > > Please explain to me the difference in the two compressors &
> > > oil
> > > > thing....I have no "horn knowledge" ~ Thanks!
> > > > S A N D Y
> > > > > http://cgi.ebay.com/ws/eBayISAPI.dll?
> > > > > ViewItem&item=2420168572&category=6763
> > > > > If anyone is interested...Just ran accross another set of
> > > these.
> > > > > New and in the box. These are exactly the same air horns
> > > (very
> > > > > nearly the same) compressor as goes on the 1985-1986 asc
> > > coupes.
> > > > > The only difference is that the compressor is not
> > > stamped "Stebel
> > > > > Junior" on top and has an oil inlet.
> > > > > Great for a backup since Hank does not have originals
anymore.
> > > > > -Mike
