3197
3199
Number: 3198
Date: Wed Jul 30, 2003 7:44 pm
Subject: Power window slop
Power window slop
I have a source that can supply the torque pins used in many
different ford power window motor drives. The torque pins are the 3
little dowel pins that transfer the motor rotation from the big gear
to the gear that moves the window. These pins crumble over time and
cause slop in the gear drive. If you remove the cover seal from motor
gear box, the three pins are located there. You don't have to replace
the entire motor assy ($100+) or the big gear assy (40+), just the
pins. If any of you folks are interested in the pins give me a shout.
3 pins (one window) are $5 plus shipping (shipping can't be much,
pins would fit in an envelope). Up to 12 pins (4 windows) per
shipping charge
Jim
jnel001@k...
